Help repairing Samsung ps50c450
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi There!
    I am currently trying to repair a TV that I bought (as broken, very cheap) 1 yr ago and tried to repair. It's a 50" plasma Samsung TV. It originally had a "clicking no start condition". There has been 2 phases for this so let me explain:
    Past (1 yr ago): TV wouldn't turn on. PS was clicking. Found that after disconecting X board it would start up internally (samsung start up tune) and all power leads (Vs, Ve...) would check good. Found a shorted transistor shorted in the X board so I swapped it (I know it's advised to replace ALL semiconductors, I tried to go cheap). Checked TV afterwards and didn't want to turn on. Got sick of it and left TV sitting for 1 year
    Present. Brought the TV back to the bench: First test: Hit power button on remote, relay clicks on, samsung start up tune sounds ok. Blank screen. Remote buttons make the status led blink. In the rear: Vs, Ve...all dead. Only low voltages present (Stand-by, 5.3v...). Actually... Logic board seems dead as no light is on neither blinking.
    I realize there's an SMD fuse on the logic board. Checked it, its OPEN. Its marked F2000, F5R (as per datasheet, 5Amps). One lead of the fuse comes from power socket, 5.3V, straight from Power Supply. Other lead checks fully grounded, 0.000Ohm to ground. I start disconnecting all ribbons from logic board one by one and when I disconnect ribbon between LOGIC and X-BOARD, shorcircuit disapppears.
    I remove X-board and all the semiconductors in the heatsink have all leads shorted to GND. It seems my repair didn't work...
    So, this is my plan, and I would like to hear if this sounds reasonable:
    -I have ordered a spare X-Board on ebay (fully checking all markings, 100% exact)
    -Instead of getting a new LOGIC board, I'm planning on piggybacking a 5Amp fuse onto the SMD fuse on Logic board, assuming nothing else is blown in the logic board so maybe I can save myself the money to get a full board.
    Do you think this all makes sense??
    Thanks in advance!!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Help repairing Samsung ps50c450
    I would replace the bad X-Main Bd when the other one arrives, leaving out the 5Amp fuse on the Logic Bd. Plug in TV and try a start-up. If No smoke or blown fuse is observed, measure if there is voltage on the connectors, shutdown and replace the 5Amp fuse. Try a start-up again and observe.
    • edugimeno
      • May 2017
      • 581
      • Spain
      Sounds like a plan, but Im unsure whether the high voltages will be present while the logic board fuse is out. Isnt the logic board the one which demands the Vs, Vg...from the PS?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes but we are taking one small step at a time to reach our final destination. Before applying ac power, measure that ground fault on the one end of the 5amp fuse and see if it still exists or vanished with everything connected.
        • edugimeno
          • May 2017
          • 581
          • Spain
          Got you now...yes that makes sense
          Tnx
          • edugimeno
            • May 2017
            • 581
            • Spain
            Ok some updates here.
            The X-Board arrived today. Broken. Yes, a big chunk in the corner was smashed. Good thing it only affected 3 real traces so glueing it back and resoldering the traces was quick.
            I put it back in place. It all seemed good. Soldered a glass 5A fuse to the logic card (see previous posts)
            Turned on. Didn't want, on/off cycling.
            Started disconnecting cables from pairs of boards.
            Problem improved (by "improve" I mean I get to hear the Samsung startup tune and it won't shutdown) when I disconnected ribbon from LOGIC to X-BOARD. Was X-board bad again?
            Wait, it only improves when I disconnect that cable from the logic board side, it is still bad when I disconnect it from the X-board side!!(attached photo of boards without this cable) So the issue is not in the board, it is the cable now!
            Yes I take the LOGIC->X Board flat ribbon cable out and inspect it. Traces 2&3 are shorted. See attached photo, you can see the plastic is slightly melted in that area.
            So I'm ordering now this cable (hopefully it's as easy to find online as the boards are!) and see what happens next...
            Thanks everyone for being there
            Eduardo
            • edugimeno
              • May 2017
              • 581
              • Spain
              ...so far it looks like locating a replacement for this flex cable is not going to be so easy...neither cheap..
              Anyone knows of any tip for this? I'm not paying $20 for a 1 ft cable to fix a tv that may still have other issues going on...
              Thanks in advance!!
              • R_J
                • 9624
                If only lines 2 and 3 are shorted, use a knife and cut between the traces where it is shorted, then put some tape between the traces to isolate them. This should get it working for doing the rest of the testing, once the set is fixed, order a cable. or check with a repair shop, they usually don't keep them.
                • edugimeno
                  • May 2017
                  • 581
                  • Spain
                  Too late for a repair for mine...I already cut it into two, expecting one half to be enough to reach between two boards going more straight. Not only no half was able to reach the length, also the short is present along the whole lenght of the cable, so in both halves.
                  Im in touch with a user on ebay who is selling a set of 3 LVDS cables for this TV to see if he can sell only one and get a better shipping cost
                  Thanks!
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Good to hear you are reaching nearer to solving your TV issue.
                    • edugimeno
                      • May 2017
                      • 581
                      • Spain
                      Thanks Andrew, although I'm pretty stuck right now due to this flex cable...
                      Will keep posting updates here
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        Ok this is hopefully the last update on this TV. I found a seller on ebay who had a post selling all the flex cables in this set. Talked hin into selling only the one I needed. He agreed. I received the needed flex cable 1 wk ago, tested it on the TV today and voila!! It works!
                        All seems good, tuning went right, image looks right, stayed on for several hours with no issue so I call it GOOD. Puts out a lot of heat...thou...
                        We were used to 32" in a small living room...now 50"...my kids said it looks like a cinema LOL
                        So I just wanted to say everyone involved in this thread, THANK YOU!
                          09-07-2024, 05:50 AM
                        • ohren
                          by ohren
                          09-08-2023, 05:24 PM
                        • jesterace
                          Samsung UE46ES8000 Blown fuse but no other signs of short
                          by jesterace
                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                          09-11-2024, 03:14 PM
                          09-06-2024, 11:40 PM
