samsung le40r73bd solved
  • petehall347
    • Jan 2015
    • 4448
    was told first sound but no pic . picked it up and he said thats not correct info on fault . no problem anyway as never listen to customer .
    brought it home and plugged in . powered up no problem and fully working . 1 hour later it dies . no pic to be seen with torch . removed rear panel and powered on whilst laying flat . everything working again so tapped power board and set goes on and off etc . removed supply and re-soldered transformer as joints broken . replaced all electrolytic through hole caps for good measure as 2 swollen in there .
    i didnt even test before putting rear cover on .. and yes it worked fine after cover on
    sorry for ranting on . thought i would share in case it helps others .
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8350
    Re: samsung le40r73bd solved
    nice easy fix!
      09-07-2024, 05:50 AM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
