Samsung UA32F40000AR Not Switching on
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Good morning,
    Samsung UA32F4000AR Not Switching on. Red standby led constantly lit when plugged in, wont respond to P function control or remote.
    Voltages measured on MAIN pcb plug CN201 (legend on PSU pcb plug CNM803) Photos 1&2
    Pin marked voltage measured voltage
    1) 13v 13.4v
    2) PWM_Dim 0v
    3) 13v 13.4v
    4) ECO_On/Off 13.4v
    5) Vamp 13.4v
    6) BLU On/Off 0v
    7) Vamp 13.4v
    8) Gnd 0v
    9) Gnd 0v
    10) Gnd 0v
    11) B5 5.4v
    12) A5 5.4v
    13) B5 5.4v
    14) Power_On/ Off 3.4v
    IC901 Winbond 25Q128FVSG (MAIN pcb)
    1) /CS 0v
    2) DO(IO1) 3.4v
    3) /WP (IO2) 0v
    4) Gnd 0v
    5) DI (IO0) 0v
    6) CLK 0v
    7) /Hold or /Reset 3.4v
    8) Vcc 3.4v
    I have repaired two of these sets before by just replacing the MAIN pcb, Could the MAIN pcb be repaired rather than just replacing it?
    Please if anybody could steer me in the right direction
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Re: Samsung UA32F40000AR Not Switching on
    The culprit stays in main cpu. So were we told at the official service repair center. In the F6000 smart models the issue relays in the emmc. Both chips are bga.
    • Grunder
      • Jan 2016
      • 323
      • south africa
      Thanks Senndogg, the customer preferred to have the pcb replaced rather than repaired. Saves me from going any other possible route. Will have to wait until the next one comes around before attempting repairing the pcb. Thanks for input.
      • pereramsm
        • Jun 2021
        • Sri Lanka
        I have same issue. my case IC201 pin 8 shows 0 voltage and shows its ground can you say is this issue with IC201 or main IC?
          09-07-2024, 05:50 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
