Panasonic tx-l32c3b mainboard fault
  • jesterace
    • Aug 2013
    • 87
    Hi i'm looking at a PANASONIC TX-L32C3B which won't turn on. It has a solid red light and will only flash in response to using the remote control. It is not giving any flash codes on it's own.
    All voltages are present on the PSU board (5vsb and 16v) however i saw that the INV_SOS pin was high (3.3v). In addition, i also saw that the INV_ON signal was low (0v).
    To try and prove that the PSU is not at fault, i injected 3.3v into INV_ON and found that the INV_SOS error disapeared (0v). Great! I had to also inject 3.3v into the INV_PWM input of the PSU too to make the backlight turn on, which it did. So this is looking like a mainboard fault. The mainboard is certainly not issuing INVERTOR_ON, but as i'm not that aware of the power sequence for this TV it might be because some other circuit has failed earlier in the chain.
    The only problem is that the schematics i could find, use a slightly different main board and it's making things a right headache to try and follow. The mainboard number is TNP8EA112.
    I've probed around as many rail voltages as i can find and compared them with a few similar schematics that i could download. It looks like i'm missing two voltages that should appear from a chip labelled bd81021.
    Anyone had to repair one of these mainboards before?
  • jesterace
    • Aug 2013
    • 87
    Re: Panasonic tx-l32c3b mainboard fault (FIXED)
    In a complete turn around, it looks like it was the mainboard at fault, but not in a serious way! I found some info about doing a factory reset via the panel buttons and the TV is now back to life! Here is what i did:
    Turn off the TV.
    Hold the F button, Vol- button and power switch on the side panel.
    Hold breath and wait for the backlight to come on.
    Fixed!
    Hope this helps someone.
    James.
    • chrislyons
      • Apr 2018
      • 39
      thank you i just done same for tv i got for tenner all works great now
      • tvdoctortv
        • Jun 2018
        • Moldova
        Hi James,
        I would like to ask you a couple questions about turning the backlight on. Can I?
        • SACR
          Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
          by SACR
          I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
          11-20-2023, 11:53 PM
        • chockimon
          Panasonic TX-40AX630B has developed a fault
          by chockimon
          I bought a Panasonic 40" TX-40AX630B TV from Richer Sounds 7 years ago and it has developed a strange fault. If I attempt to press any button on the back of the TV or remote control (access media features etc.) the TV locks up for a few minutes or longer and sometimes goes blank. However, if I turn the TV off and on again and quickly select a channel it will work fine all day long, as long as I don't touch the remote or controls on the back of the TV.
          I've tried changing batteries on the remote, changing plug sockets and doing other things such as a...
          06-02-2022, 12:03 PM
        • fixxy88
          Panasonic 55DX600u second fault - panel brightness pulsing on right side
          by fixxy88
          After getting the backlights up and running a second fault has emerged on this TV. I was going accept defeat and move on but thought I'd have a quick look at it in case it was something simple. The right side of the display exhibits a panel brightness (not backlight brightness) pulse every 2-3 seconds in a stable timing.
          I poked about on the TCON test points and found one voltage that is fluctuating in the same pattern. VGH-ODD (Pin 47 of U10) is sitting at ~-6.5v then goes up to ~28v when the brightness pulses then goes back down to ~-6.5v again in a repeating pattern.
          03-22-2023, 02:58 AM
        • Andre Gilbert
          by Andre Gilbert
          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
          11-20-2024, 08:52 PM
        • Sebastijan V.
          Samsung UE40K1502AKXXH - flashing LED, no life but still responsive
          by Sebastijan V.
          So, I got this UE40K1502AK(XXH) TV from a friend.
          TV has no picture or sound, but it reacts on remote control and power button on bottom side.
          - When plugged into mains, the LED is red on. If I use remote to power it on for the first time, it flashes 6x then LED remains off. I assume this would be the same as by normal tv?
          - LED also flashes fast when I push any button on remote controller. If I turn it off with remote, the LED will lit solid red. And by next turn-on with remote, it flashes 5x. Also will flash fast when any remote button is pressed.
          - The background...
          03-20-2025, 04:22 AM
