Tx-p42ut30e
  • samtron786
    • Aug 2016
    • 170
    • germany
    Tx-p42ut30e
    hi Guys
    I have sound problems, sound scratching between 3 to 5 minutes, that goes off
    Thank you
  • samtron786
    • Aug 2016
    • 170
    • germany
    Re: Tx-p42ut30e
    oder den Ton ist undeutlich
    • tw2005
      • Oct 2011
      • 6458
      Re: Tx-p42ut30e
      Was passierte mit der Übersetzung?
      Could be worth examining the speakers themselves in particular the edging. I have found with age and heat that deteriorates and separates. That will stop the speaker from working correctly
      • samtron786
        • Aug 2016
        • 170
        • germany
        Re: Tx-p42ut30e
        Hi
        I also have the boxes separated unfortunately no sound but exactly between 3 to 5 minutes is turned off
        • tw2005
          • Oct 2011
          • 6458
          Re: Tx-p42ut30e
          Originally posted by samtron786
          Hi
          I think something is being lost in translation. Are you saying the speakers are falling apart?
          "Is turned off", the TV turns off or tv is on and no sound?
          That's all I have experienced with sound issues. Maybe the speakers are so bad they stop functioning?
          • samtron786
            • Aug 2016
            • 170
            • germany
            Re: Tx-p42ut30e
            I have to test just the two Lauspeicher mated, so I know if the TV goes out
            the Tv is turned off, a question how can you test the latsave if there are any errors ??
            if I plug in the loudspeakers or disconnect the TV goes out
            • samtron786
              • Aug 2016
              • 170
              • germany
              Re: Tx-p42ut30e
              when the TV goes out, then the red led flashes, I have to pull the plug
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Re: Tx-p42ut30e
                Do you have the same problem with the headphones connected?
                • samtron786
                  • Aug 2016
                  • 170
                  • germany
                  Re: Tx-p42ut30e
                  right has more problems
                  • samtron786
                    • Aug 2016
                    • 170
                    • germany
                    Re: Tx-p42ut30e
                    According to this info shows 12 flashing Sound SOS H board
                    what's the problem with SOS H board here?
                    https://www.brainchamber.com/panasonic-tv-blink-codes/
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Re: Tx-p42ut30e
                      Its normal that the tv shuts off when you remove the loudspeaker plug from the mainboard.
                      The mainboard detects a problem with the sound and goes into protection.
                      You need to figure out if you have the same problem with headphones plugged in. Does it happen with HDMI or also with component/scart etc?
                      • samtron786
                        • Aug 2016
                        • 170
                        • germany
                        Re: Tx-p42ut30e
                        I wanted to test loudspeaker plug, if loudspeaker plugs are defective therefore remove loudspeaker plugs from the mainboard.
                        unfortunately not yet tested with headphones
                        how to check a bad filtering (ripple) in the circuit
                        • samtron786
                          • Aug 2016
                          • 170
                          • germany
                          Re: Tx-p42ut30e
                          hello, I have exactly the same problem with headphones
                          • ChaosLegionnaire
                            by ChaosLegionnaire
                            09-13-2022, 09:02 AM
                          • Christos Tsiligiannis
                            Marian Trace Alpha sound card repair help
                            by Christos Tsiligiannis
                            Hello to the forum.
                            My name is Christos, I am new to the forum here and i am posting from Greece.
                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                            11-18-2024, 05:26 AM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:30 PM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
