Black Screen won’t power on
  • djjonglee
    • 10
    • canada
    Newbie here, just wondering if someone can help me out
    I have Samsung UN50EH5300FXZC Ver. PJ05
    Black Screen with standby Light on and sometimes blinking
    I have read some treads for troubleshooting but still confuse
    I have check for burn capacitors but all are good, connections are also good
    done plugging it on with the main board disconnected and backlight
    Is showing on, some say it was the main board some say it's T Con.
    Is it worth fixing this TV to buy the parts or no.
    What parts I need to replace and where to get them
    Thanks in Advance
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Black Screen won't power on
    Do you have voltage on both sides of fuse on t-con board?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • grimacelord
      HP 15-EH1070wm - Black Screen With Power LED.
      by grimacelord
      I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
      First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
      01-28-2023, 10:50 AM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • rybby
      Acer Aspire 5 A515-51 power on but black screen
      by rybby
      I have an acer aspire 5 a515-51 that turns on but has a black screen.
      This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
      Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
      06-16-2023, 09:41 AM
    • burntonnerings
      Acer K272HUL blue power light but black screen, power supply is ok
      by burntonnerings
      Have had two Acer K272HUL monitors die with the same symptoms:
      - Blue power light is illuminated while the monitor is plugged in
      - Black screen (no splash screen, etc.)
      - Power button doesn't do anything
      Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
      Power supply voltages are fine.
      There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
      Anyone have any ideas?...
      12-09-2023, 10:22 PM
    • samolo75
      Asus Laptop GL702VS black screen power LED on
      by samolo75
      I am fighting with this laptop and I am suspecting of the GPU, but it would be great to know your opinion.
      The laptop originally does show black screen (no back light) but the power button LED turn on and off when pressing it.
      I did the next trouble shooting with no changes
      - Disconnected the battery and try just with the power supply
      - Disconnected all power sources, even the CMOS battery and held the power button for 40sec.
      - Disconnected hardrives
      - Deplaced the RAM
      - Disconnected the Wifi module
      - I connected a external monitor to the...
      03-31-2021, 03:16 PM
