Samsung UE40C5700 Mainboard Mainbaord No. BN94-04496V
  • samtron786
    • Aug 2016
    • 170
    • germany
    My Samsung TV does not respond with remote control, can someone help me, where is the problem?
    Batteries are new all contacts Clean, remote works
    that's a hardware issue, I'm sure
    I already have new firmware update, did not help me
    from time to time remote control works, you can work with it but not always
    the remote control is OK, the TV problem
    Thank you
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung UE40C5700 Mainboard Mainbaord No. BN94-04496V
    The Remote Control could still be faulty. Open it up and look at the few soldered points. They could become loose and need reheat to secure their connections. Battery could have leaked and a little acid could have contaminated the circuit board.
    • samtron786
      • Aug 2016
      • 170
      • germany
      Hello, I have two remote controls working, orginally all are battery
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        OK. So you have two working remote controls that are working. Look now at the IR receiver board on the TV and see if there is any obstruction or loose soldering on the IR receiver and on the connector/wiring to the Main Bd. Inspect the connector on the Main Bd., too.
        • samtron786
          • Aug 2016
          • 170
          • germany
          OK thanks
            09-07-2024, 05:50 AM
          • tmhobadcap
            Pioneer VSX-522-K remote control not working???
            by tmhobadcap
            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
            12-24-2020, 01:44 AM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • piipo
            Old Privileg 5.1 speakers remote control question
            by piipo
            Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
            09-18-2024, 01:55 AM
          • Sebastijan V.
            Samsung UE40K1502AKXXH - flashing LED, no life but still responsive
            by Sebastijan V.
            So, I got this UE40K1502AK(XXH) TV from a friend.
            TV has no picture or sound, but it reacts on remote control and power button on bottom side.
            - When plugged into mains, the LED is red on. If I use remote to power it on for the first time, it flashes 6x then LED remains off. I assume this would be the same as by normal tv?
            - LED also flashes fast when I push any button on remote controller. If I turn it off with remote, the LED will lit solid red. And by next turn-on with remote, it flashes 5x. Also will flash fast when any remote button is pressed.
            - The background...
            03-20-2025, 04:22 AM
