Samsung ln46c530 works until turned off then must unplug
  • Chrishag
    • Dec 2017
    • 7
    • Usa
    OK so TV was working fine however recently when turned off you must wait 5 to 10 minutes or unplug the power for the TV to turn back on. Once on runs fine until turned off.
    Attached are pictures of the main board and power supply I did not see any obvious bulging caps wondering what my next steps are in trouble shooting this TV. When it will not turn back on the red standby light is on and then starts flashing when you press power button
  • Chrishag
    • Dec 2017
    • 7
    • Usa
    Re: Samsung ln46c530 works until turned off then must unplug
    What should I be testing 1st. I would love to get this back up and working
    • budwich
      • Jul 2015
      • 3097
      is there any pattern to the flashes of the led to indicate some code?
      • petehall347
        • Jan 2015
        • 4438
        • United Kingdom
        there is a broken rca plug pin in one of the sockets
        • budwich
          • Jul 2015
          • 3097
          good spot... hopefully its not touching anything that it shouldn't.
          • Chrishag
            • Dec 2017
            • 7
            • Usa
            Once you shut off the TV the red standby light is on pressing power again on the remote the light will blank five times but the TV will not turn on
            • Chrishag
              • Dec 2017
              • 7
              • Usa
              Good call I missed that when I originally opened up the back panel just remove the broken plug fortunately it does not look like it was touching anything underneath it. Tested TV again after removing and still experiences the same symptoms
              • budwich
                • Jul 2015
                • 3097
                anyways, since it is a readily repeatable condition, just do the basic tests to see whats up. Basically, when you power down and then power up and get the flashing condition, keep repeating the test BUT go and check all the voltages that are printed at the various connector areas on the main board / power board to see what they are like. Further since you know how to get it working (unplug / plug / power up), do that sequence and do the same checks and see if you can spot a difference. Go from there.
                The other thing perhaps is to check the connectors to ensure they are seated well (maybe reseat).
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Samsungs have a usual blinking pattern to them before they power up. Samsungs also do not have a error code blink output.
                  1st thing I would do is open it up and get some voltage readings off the pin out that goes from the power supply to the main board. I'm suspecting a 5v standby dying off or low upon powering back up again. Questionable AC Detect pin. Could be a primary output side of the power supply issue. Check caps on primary side and what their standing voltage is in standby after first plugging it in and then after running it for a while then turning it off and checking voltage there again.
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
