Vizio E552VLE Troubleshooting
  • cditi89
    • May 2016
    Hey guys,
    I have a Vizio E552VLE that I'm currently trying to fix. The symptoms are that the TV will not turn on. There is no Vizio light illuminated on the front when plugged in. It just went out one day and didn't turn back on or so I'm told.
    Well, troubleshooting this TV has got me at a bit of a loss. The fuses are fine on the power supply board which is an 0500-0513-1140 (N312A001L). This was my first idea seeing as there is no Vizio light in the front. When testing voltages on the board there are 5V+ there to the main board but no other voltages from the connector are present even when the power button is pushed. I did check the other connectors for shorts (not the same one that goes to the main board but the T-con boards?) seems okay? A resistance reading of ground to the 12V on those connectors increase in resistance?
    The main board is a 3655-0422-0150 (0171-2272-4314). It is getting the 5V and the fuses are fine there as well. I'm assuming the main board is bad because there is no remote V to the power supply when the power button is pushed. The Vizio light on the front also goes through the main board which furthers my suspicions.
    Problem being is I'm having trouble trying to find a main board for this TV IF that is the problem. Any guidance would be appreciated. I will take pictures as soon as I can.
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
    by JDC
    ONN 100012588
    Issue: No Power, Then Rebooting After Main Board Change
    Short answer: replace main board and power board
    Technical answer: replace main board and Q306 & Q307 on power board.
    Long answer:
    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
    07-15-2022, 07:39 AM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Arkiered
    Vizio E552VLE Main Board
    by Arkiered
    Hi everyone, I am looking for a schematic diagram for the Main Board to a Vizio E552VLE. I have 5V Stby good and solid, but I get no Pwr On signal. If I jumper 5V to it, the Power Supply has 12 and 24V, but I also get no signal to turn the backlights on. Any help is appreciated, Thanks.
    10-23-2022, 05:43 PM
