sharp lc-70le747kn do i cut panel driver ribbons off ?
  • Critter202033
    • Dec 2017
    • 5
    Re: sharp lc-70le747kn do i cut panel driver ribbons off ?
    So just gotta live with it or change it I guess. Thanks for all your help.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Jidis
      Need T-Con Advice (Vizio P602ui-B3)
      by Jidis
      I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
      He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
      09-22-2025, 05:10 PM
    • advant
      by advant
      02-03-2020, 12:25 AM
    • Andrew453
      Crestron TPS-2000L with Sharp LQ5AW136R panel
      by Andrew453
      I have numerous Creston TPS-2000L touchpanel home automation devices, which incorporate a Sharp LQ5AW136R panel. They all exhibit the same fault. They are about 10-15 years old.
      The fault can be seen in the attached photo. Basically the displays are all washed out, to be point of being unreadable.
      Clearly it's an issue with the panel. But my question is whether it's just aging related (e.g. all the pixels in the LCD wearing out) or whether it could actually be a more specific component (i.e. one capable of being individually replaced). I've seen suggestions on other...
      01-28-2023, 02:54 PM
    • MoreMagnets
      Sony KD49X8000H - Sound, backlight, no picture
      by MoreMagnets
      Hello all!
      This post will mostly just act as documentation for my undertaken troubleshooting steps for this TV. Advice will also be appreciated for things to try next
      Picked up the TV in thread title from a retail returns auction, symptoms were as described. I started my troubleshooting attempts by shorting the 19V PSU rail to the 3v rail with my multimeter... Doh. Big spark, dead PSU, TV not turning on anymore. Picked up a new mainboard and PSU locally from someone here in Sydney, wasn't sure if my butterfingers had killed both and was a big drive to pick them...
      10-23-2022, 09:31 PM
