Samsung LE40M86BD missing HDMI in source list
  • lesnajair
    • May 2015
    • 57
    • United Kingdom
    Hi
    As above, after a recent factory reset, the only options for source select are TV, EXT1 and EXT2. Entering the menu and source list everything bar the mentioned sources is greyed out. I have the exact same problem with another Samsung LE40M87BD. Looking for an answer online tends to throw up a 'factory reset' solution which works in some cases but not in most cases. Does anyone else have experience in restoring these functions please? I have factory reset this tv 4 times with the same result!
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Re: Samsung LE40M86BD missing HDMI in source list
    Might be a stupid answer but have you an active HDMI source connected? If not on some TVs it does not show up as an option.
    • lesnajair
      • May 2015
      • 57
      • United Kingdom
      Hi
      Yes, I have my active source coming from my sky hd box.
      • lesnajair
        • May 2015
        • 57
        • United Kingdom
        Re: Samsung LE40M86BD missing HDMI in source list SOLVED
        Can't believe I was so stupid!
        I had the wrong source (HDMI) installed. Thought it was pink plugged one from sky box but that was wrong one! Used the right one and all working as normal. Tried all HDMIs one by one and they all show up in source list!
        Thanks again.
          09-07-2024, 05:50 AM
        • nader_guesmi
          Samsung UE65TU7172 – BN41-02751C – CI+ ECP Keys Missing / Digi Card Not Working
          by nader_guesmi
          Hey everyone,
          I’m working on a Samsung UE65TU7172 with mainboard BN41-02751C. The TV powers on normally, I’ve applied the latest software update, and all measured voltages are correct.
          Problem: The CI+ module doesn’t read the Digi card.
          I accessed the service menu (using Mute + 2 + 4 + 7 + Exit) and ran the CI+ test. The results show:
          • CI+ production keys: Success
          • ECP keys: Not installed
          So the TV doesn’t even attempt to communicate with the CAM/card.
          I’ve tried multiple Digi cards (both old and new), and they work fine on another...
          09-09-2025, 03:04 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
