lt27b551ew samsung syncmaster
  • jonny78
    • Apr 2017
    • 72
    hi guys picked up this set screen looks good...didn't come with power supply so used the power supply off my main TV which is the same.. plugged it in and...pop.. the fuse blows on the plug..now the plug i used was a 250v 3amp this tv on the back says 100-240v 1amp could the higher voltage plug have caused the fuse to blow or is that silly ? lol or could it be something on power supply at fault that causes this?
    not had chance to open it up yet which i will in due course!
    cheers!
  • jonny78
    • Apr 2017
    • 72
    Re: lt27b551ew samsung syncmaster
    managed to open it up and several components have blown the fuse being the main one... ive desoldered all the blown components but cannot make out what some of them are as they are badly damaged... power supply number is bn44-00504c and i cant find any info on this board..would it be worth trying to repair this or just buy a replacement board?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Can you post pictures.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        09-07-2024, 05:50 AM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
        03-31-2024, 02:12 PM
