Samsung HP-T4264 ~ Clicking and no picture or sound
  • kca
    • Feb 2016
    • 529
    Re: Samsung HP-T4264 ~ Clicking and no picture or sound
    Andrew F. Ali (or anyone) ~~
    I found this video (see below), that explains how to short the PS_On pin to another pin in order to then test the remaining voltages on a PSU. The title of this video cites an LCD tv. Do you think I can perform the same test on this Samsung plasma? If so, which exact pin would I connect the Ps_On pin to in order to create the proper short?
    All of the connector labelings can be found up in my very first post on this thread.
    https://www.youtube.com/watch?v=mUvclBfaMXg&sns=em
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Andrew F Ali gave an explanation on how to test the power supply in an earlier posting.
      • kca
        • Feb 2016
        • 529
        Yes, I’m going to get those light bulbs together and rig up that test w/ the 2 120W bulbs in sequence. I’m just wondering if there is an easier way to do virtually the same thing.
        In the video, he connects the PS_On with an adjacent 5vSb pin, then was able to test the Vs and VA. Does this work with any PSU? I’d like to try that first, assuming it’s safe to do.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          It's a standard test for plasma screen power supply as far as I know.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I don't have a video for this PLASMA PSU 'self-test'. The light bulbs are everyday household 120Vac 100W bulbs. Note however this 'self-test' applies to PLASMA TV PSUs only, NOT LCD TVV PSUs. Just follow the step by step procedure I offered and that will confirm any doubts you may have about the PSU. Remember once the light bulbs light bright continuously, measure you Va and if it falls into spec then the PSU is good. There would be no need to look at the PSU again if this test proves successful. You can now look at the other boards, and I there are 'self-tests' we will explain after, But do the PSU test first to rule that out as a start.
            • kca
              • Feb 2016
              • 529
              I did some more investigating on this PSU and found that there are at least two SMD resistors that are damaged. Based on quite a bit of research I just conducted, and looking at a wide variety of repair kits that are out there on the market, I figure there are about four or five more SMD's that probably need to be replaced as well in order to ensure the fix. Also found two 10 ohm resistors on the front of the board that need replacing. If I attempt to fix this, I will also have to replace the MOSFETS as well (QS801 and QS802 for sure, and then also QX801 and QX802).
              Never did the MOSFET replacement before, or the SMD's. It's much more involved that I was hoping for when I first opened up the set. I might just use the whole thing as a practice session to improve my skills and hope for the best.
              But, before I dig into it in this rather involved way, I am wondering if anyone out there has suggestions for a reputable and reliable MAIL-IN repair service that I could send it to. I found one online called Preher-Tech and have written to them. They were fixing these exact boards for only $50 between 2011 and 2016 (the dates of the online blog), but it looks like they may have gone out of that particular mail-in fix business. I'll write back here if I get a response from them by e-mail in the coming days, but hoping I can gather up some more MAIL-IN repair options here through Badcaps.
              Thanks in advance for any ideas / suggestions anyone may have.
              ~ kca
              Here is a link to that rather involved and lengthy blog from Preher-Tech that I mentioned above:
              http://preher-tv.blogspot.com/2010/0...-repaired.html
              The PSU part # in question here is BN44-00161A, the same as on my Samsung HP-T4264
                09-07-2024, 05:50 AM
              • meeotch
                Samsung PN64H5000 clicking when powered, then stuck in standby
                by meeotch
                My PN64H5000 shut itself off/on/off a few times in succession last night, then refused to turn on again. When I first plug it in, I get five clicks coming from the power board, and the red standby light on the front goes on and off, as does the little green LED on the logic board. After that, the red standby light comes on after a couple of seconds and stays lit, but the TV will not power on. Confirmed by leaving it unplugged overnight.
                I opened it up, and didn't see any bulging caps, burnt PCBs, or anything else obvious. Tested the two fuses I saw on the power board (one removable,...
                09-27-2021, 02:57 PM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
                09-06-2024, 11:40 PM
