Sharp lc-60eq10u power issue
  • joec9999
    • Aug 2017
    I have a Sharp lc-60eq10u with power board DPS-167CP A. The symptom is two slow blinks followed by two fast blinks from the led on the front of the TV.
    I looked up the error code in the service manual and see it is related to UR+13V.
    I removed the power board and powered it up on the bench by connecting PS_ON to BU5V and was able to power up the board. UR+13V was present measuring about 13V. I also measured the voltage at C7800A/B and found that it started up at about 175 VDC and slowly climbed (took about two minutes) up to 395 VDC.
    At this point, I powered down the board and resoldered some questionable connections and put it back into the TV. After reapplying power, the TV showed the 2/2 blink error pattern again (without pressing the power button). I then pressed the power button and the TV powered up and played all day.
    I unplugged the TV and let it sit overnight. The next day I plugged it back in and the TV showed the 2/2 blink error again.
    The one thing I question is the +395 V across C7800A/B and how it took so long for it to build up while I was testing it on the bench. Could this be the issue?
    I'm not absolutely sure this is a power board issue and would like some input on this.
    Thanks in advance,
    Joe
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sharp lc-60eq10u power issue
    I believe you should have your 175vdc at standby, and get your 395vdc almost instantaneously when powered on.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      The e-cap/s C7800A/B is probably bad...It my not show any physical evidence...The capacitance probably decreased over time.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • justice171
        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
        by justice171
        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
        1. Verified that all critical voltages are present:
          • 3.3V and 5V are always present if DC is plugged.
          • 1.8V on the BIOS chip is present.
        2. Checked the power button functionality:
          • When pressed, the voltage drops to 0V, indicating the button is functional.
        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
          • Confirmed connectivity is intact, ruling out issues
        11-26-2024, 12:39 AM
      • claws77
        lenovo flex 5 14itl05 power sequence issue
        by claws77
        hi guys, my motherboard will not start no matter what
        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
        but rest nothing happens no sign of life.
        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
        i have no knowledge of motherboards ....
        10-20-2024, 02:48 PM
      • yaya3gmax
        Laptop Power Issue – Works on Battery, Fails on Adapter Load
        by yaya3gmax
        Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
        Symptoms:
        • Laptop works normally on a pre-charged battery.
        • Battery does not charge when adapter is connected.
        • Without battery:
          • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
          • Speakers “pop” when power cut occurs indicating harsh sutdown.
          • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
        Yesterday, 07:16 AM
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
