Samsung le40c550j1w
Re: Samsung le40c550j1w
I found the firmware and installed this but the problem is tv works fine but when powered off at about 10min and powering on the tv it goes on a cyclus of 6 blinking led 3times before powering on again.
Someone knows the problem.Comment
what are the power supply and main board part numbers that are used in this tv.Comment
Model l40f1_ady
Powersupply bn44-00340b
Mainboard bn94-03391d
This is an mainboard of le46c550j1wx
I installed it on a 40inch
My original which is broken is the bn94-03391bComment
All I can find on BN44-03391D is that it is used in a Samsung LE46C550J1WX set. I wonder if it's having problems because of the different panel size. When you next have it running can you enter the service mode and see if your panel is available to select in the service menu.Last edited by dick_barton; 09-06-2017, 03:55 PM.Willing to help but I'm no expert.Comment
My panel is LTF400HM01All I can find on BN44-03391D is that it is used in a Samsung LE46C550J1WX set. I wonder if it's having problems because of the different panel size. When you next have it running can you enter the service mode and see if your panel is available to select in the service menu.
In service menu it was first 46A6AF0C
I changed it to 40A6AF0C
Problem stil exist.
Mainboard is new not a swap.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by JacksoftHi all,
I got an old Samsung 225MW TV with BN41-00825 motherboard.
Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
So I attached the VGA UART cable and read the debug data using a RT809H programmer:
According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts... -
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 Photos08-24-2025, 03:47 AM -
by bohabohaHello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
