Samsung ln40c630k1fxza no backlight
  • curranb
    • Aug 2017
    • 16
    • Usa
    I'm looking for help with my Samsung ln40c630k1fxza. The set powers up, has sound but no picture. However, shining a flashlight on the screen reveals that there is a picture just no backlight. The last few times the set had been used the screen flickered for a few seconds at startup until a normal picture appeared. Now it will not light.
    After reading several threads on this issue in this forum and others I took a chance and replaced the power supply capacitors that have been known to fail in these sets. Unfortunately there was no change.
    I've downloaded the schematic for the power supply (bn44-0034b) from this site. Below are the readings at the connector that runs to the main board:
    Pin Desc. Reading
    1. B13v. 13v
    2. 5v_DET. 0v
    3. B13v. 13v
    4. BLU_ON 2v
    5. B13v. 13v
    6. E-PWM. 5v
    7. GND. 0v
    8. H_SYNC. 0v
    9-10. GND. 0V
    11. B5v. 5v
    12. GND. 0v
    13-14. B5v. 5v
    15. B13v. 13v
    16. A5v. 5v
    17. B13v. 13v
    18. PS_ON. 1.5v
    I also took measurements at the connector to the inverter board
    1. Vcc B12v. 13.24v
    2. FB2. 0v
    3. FB1. 0v
    4-5. GND. 0v
    6. LD. 12.38v
    7. LD. 12.38v
    All readings were with the tv powered up. Any ideas or next steps?
    Thanks.
    09-07-2024, 05:50 AM
  • sansanpartida
    Samsung QE82Q70RAT no backlight
    by sansanpartida
    Hi everyone!
    Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
    My issue: No backlight.
    Model: QE82Q70RAT
    Type No: QE82Q70RAT
    The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
    So hopefully, I can fix this cheaper.
    05-22-2024, 06:56 AM
  • howardc64
    Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
    by howardc64
    TV was fixed just after removing Samsung's rear snap cover.
    This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
    Maybe PSU->backlight connector didn't have a good contact?...
    07-23-2025, 12:34 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
