Sony Trinitron KV1926RA No HV
  • Vitam
    Class A Geek
    • Aug 2017
    • 45
    Hi! I found a Sony Trinitron KV1926RA TV set from February 1990. It had been out in the rain for a short period of time, then dried. A few drops when I first plugged it in. It's really cool because it has a "SIMULATED WOOD" sticker on the side, haha! So, of course, it didnt work so I took a hair dryer and Q tips to the motherboard, and dried and cleaned it. Now, the relay clicks on/off normally but no picture and I can't hear the flyback! What can this be? On the main board, there is a fuse for the flyback I think, and its OK. The big mains fuse is a little white on the ends, but I think its also ok. The big cap was bulging but turns out it was just the plastic cap expanding. Thanks!
  • cmonkey
    Sony Trinitron KV32FV27 Suddenly Dimmed
    by cmonkey
    A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
    I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
    I'd say I had it on for about 15 minutes or so and then lugged...
    04-28-2023, 06:25 PM
  • motorahead
    Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
    by motorahead
    Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
    After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
    10-21-2023, 03:50 PM
  • ptcriserx3
    Sony trinitron crt bowed and side color issues
    by ptcriserx3
    Hi
    Ive got a vintage 2001 sony trinitron flat tube tv
    The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
    See many images attached...
    Just windering if this is not fixable or something i can correct without getting too invloved
    Im trying to sell the tv
    06-17-2023, 07:27 PM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • sickboy
    Strange CRT Fault (Sony Trinitron M1410U)
    by sickboy
    This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
    11-10-2024, 05:02 AM
