need Vestel 17MB35-4 Boot file bin
  • rawan
    • Oct 2009
    • 57
    Hi
    I have Moser Baer tv , chassis 17MB35 , MCU is MST6WA7GQ
    Tv some times work ok , somethimes front led blinking problem,
    I change all caps in power supply, i run tv with power supply and inverter by applying power on signal and backlight voltage to smps ,without motherboard,
    tv runs ok but with Main board tv sometimes works or front led flashing,
    even i did spi flash program but still same problem, i heard that i need boot bin file comes with some other files load in usb and with usb insert in tv problem can be solved,
    Please upload these files if some one have,
    Mac
  • m1ch43lzm
    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
    by m1ch43lzm
    Hi everyone
    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
    There's also an extra OTP Secu.R...
    09-06-2025, 05:47 PM
  • Grut
    JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
    by Grut
    My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
    Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
    When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
    Can anybody help me please finding the 17MB171 USB firmware to try to upload...
    11-15-2024, 03:12 AM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
  • Forest79
    by Forest79
    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
    07-23-2023, 07:39 AM
  • Luke Anders
    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
    by Luke Anders
    A few details about the laptop itself:
    Name: Lenovo Legion 5
    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
    BIOS Version: GKCN60WW
    EC Version: GKEC65WW
    Serial Number: PF39AQ7Z
    Board Model: NM-D562 Rev 3.0
    RAM: 16GB Installed, DDR4 (brand new)
    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
    I bought this laptop recently from eBay as a faulty device....
    10-12-2024, 05:13 AM
