60PB690v
  • thuss
    • Jul 2012
    • 321
    60PB690v
    Hi
    I was wondering if anyone can help me with this one?
    The tv comes on but theres no picture.
    All the voltages are fine on the psu i.e va is 55v and vs is 204v both are constant.
    On the Z sus (photo three top connection block) the 18v is not there (its about 5v) .
    On the ysus the vsc is fluctuating from 3v to 40v continuously.
    There are no lights on the tcon or the main board.
    (next step I was going to connect RL to 5v and disconnect the main board)
    Any advice would be appreciated - Thanks in advance
  • Hamie
    • Apr 2014
    • 1383
    Re: 60PB690v
    Common fault on these are 4 shorted igbts on the underside of ysus. A shorted or blown smd cap on the top buffer. And (sometines) an open fusible resistor.
    Although I've need seen the resistor open or know it's position.
    Try unplugging the buffers and see if vy stabilises.
    There is also a see a pin marked vsc that connects the y-sus to buffers.
    • thuss
      • Jul 2012
      • 321
      Re: 60PB690v
      Thanks for the reply.
      When you mention the vy - do you the 18v?
      I did check the igbts but they read ok- but I was a bit unsure because they look like there on the same circuit??
      If there is a blown smd cap on the upper buffer can I replace it or does it mean a complete new upper buffer?
      • Hamie
        • Apr 2014
        • 1383
        Re: 60PB690v
        No vy sound be around -180
        If you unplug the buffers and the y-sus gives a stable voltages then you. May only have a problem with the buffers.
        Yes, Easy to replace the smd cap.
        • thuss
          • Jul 2012
          • 321
          Re: 60PB690v
          I removed the upper buffer -vy was in the 50v range (fluctuating). Removed the bottom buffer and reinstalled the upper buffer and the vy as you stated was 187v.
          I was just wondering can I repair the bottom buffer (if the large chips are blown its beyond me) or is it a total replace of the bottom buffer.
          Thanks again Hamie for the advice.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Re: 60PB690v
            Watch some youtube videos on how to test y sus buffer boards. Norcal has a good one.
            You also should test all the smd capacitors on that board against the top buffer.
            • thuss
              • Jul 2012
              • 321
              Re: 60PB690v
              I did exactly what Norcal715 and runforlife on their buffer test,
              I am getting no beeps whatsoever. I even increased the range but still no beeps (ohms continuity).
              But I am reading short on three smd capacitors, one at the top of the lower buffer and the two caps which are above and to the right of the bottom chip.
              One other observation I forgot to mention - when I installed the upper buffer with the ysus (vy was 187) I didnt really get a grey half screen across the top half all I got was loads of pixels.
              • thuss
                • Jul 2012
                • 321
                Re: 60PB690v
                Theses are the caps (circled in red just about visible) that are reading short but when I do the buffer tests - I get no beeps
                Also I compared smd caps to the upper buffer there is no beep.
                I increased the range of the multimeter (in ohms) still no beeps.
                I cant get a buffer at the moment -I looked everywhere.
                Anyone repaired one of theses buffers- or have I got a leaky chip thats not showing up whilst doing the test?
                Thanks in advance
                • Hamie
                  • Apr 2014
                  • 1383
                  Re: 60PB690v
                  That cap is a 4nf 50v
                  Change it out and solder a 4nf ceramic through hole to the pads.
                  • thuss
                    • Jul 2012
                    • 321
                    Re: 60PB690v
                    Will do thanks
                    • thuss
                      • Jul 2012
                      • 321
                      Re: 60PB690v
                      Can I use this KEMET 4.7nF Multilayer Ceramic Capacitor MLCC 50 V dc ±10% X7R Dielectric 0603 Max. Op. Temp. +125°C? (its at Rs)
                      • thuss
                        • Jul 2012
                        • 321
                        Re: 60PB690v
                        Tv's working again - thanks Hamie you know your stuff (by the way I used a 4.7nf 100v)
                        • Hamie
                          • Apr 2014
                          • 1383
                          Re: 60PB690v
                          • legg
                            LG 42PC3 buffer output doesn't follow YSUS
                            by legg
                            LG42PC3D -UD originally with green lamp but no display or audio.
                            Owner says was working, then went 'pop'.
                            All 5V caps bulging. replaced.
                            All PSU output voltages within spec but -Vy is low on YSUS.
                            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                            eventually shorts DG. Replaced all 3 - -Vy now OK.
                            Y scan buffer test point does not follow YSUS output below -50V
                            Note: This unit seems to expect YSUS output to park at -Vy in between
                            drive signal pattern periods. A replacement drive signal board confirms this....
                            11-18-2021, 11:49 AM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • PlasMatt
                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                            by PlasMatt
                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                            09-20-2025, 06:50 PM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • Yanleb
                            Schematic or datasheet for Plasma TV buffer chip
                            by Yanleb
                            I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                            So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                            Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                            05-18-2022, 01:36 PM
