Sony KDL-40S2010 was on the trash pile bad caps
    • Jul 2011
    • 6070
    Found this TV at side of the road-----> sitting all by it self just waiting for someone to pick up
    Found three 1500uf@25 volts had pop there lids KZH
    I did not have 1500uf@25 volt ones ----> left side of the photo
    So I put four 1000@35 volt KY ones -----> that all I have in my parts bin that would fit and had the right voltage rating I know it is 500uf off of what was in there is that going to be a problem
    The TV works good but the four caps that are together they are little warm to touch and this is after running for 30 minutes is this going to be a problem
    Here is a photo of the screen of that TV set it has a very good
    • Jul 2011
    • 6070
    Re: Sony KDL-40S2010 was on the trash pile bad caps
    The TV set has run for 3 hours and seems fine so far
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Use the 1000uF caps as a temporary measure. If you can't get 1500uF use 2200uF. And yes it was OK to use 35V in place of 25V caps. So in essence replace for normal us the 1500uF 25V caps with 2200uf 35V as the 2200s may be easier to get. A little warm is 'normal' too for some caps. Good luck.
        • Jul 2011
        • 6070
        When I place another order for caps I will order them
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
