Samsung ku model fault standby mode
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    Hi guys I have a fault with a couple of new Samsung tv's mainly the Ku models.
    1.ue40ku6000 I've tried 2 different mainboards in this tv and it turns on and shuts off. I know the tv definitely works as I had a working skateboard in it but needed it for another tv.
    I've had this same issue with a ue55ku6470 and ue49k6300. I know you obviously need the correct main board bn numbers but I'm going through loads of damaged screen tv's just to find the correct working board even though they have the same bn numbers. I can't find any other numbers that correspond with the screen to suggest it's the right one. Hope this makes sense and thanks for taking the time to read
  • Diah
    • Feb 2013
    • 6355
    Re: Samsung ku model fault standby mode
    what do you mean with turn on? back light come on then out or you are talking on the 3 LED indicator on the T-CON
    pull out the cable from Power supply to MB then tun on this is back light test should be on if they are OK
    i had faced before 2 sets KU7000 & 7090 both like want to start and reload again. both was LCD fault
    • andrews7523
      • Apr 2015
      • 117
      • lancashire
      These models dont have tcon boards. The backlights work on both when the cable is disconnected
      • Nick's Tvs
        • Jan 2014
        • 621
        Is this the main board your tv uses?
        http://www.ebay.co.uk/sch/i.html?_fr...1233L&_sacat=0
        If so, try disconnecting half the screen (left vs right ribbon) and see if the tv still cycles. If that doesn't work, disconnected the other ribbon cable and plug the other one back in. If that still doesn't work, disconnect both ribbons and see if the TV still cycles. If you still get the cycling, then indeed it would seem as if you have a bad main board.
        • Hamie
          • Apr 2014
          • 1383
          https://www.badcaps.net/forum/showthread.php?t=67341
          Please read
            09-07-2024, 05:50 AM
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • ChristianBr01
            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
            by ChristianBr01
            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
            04-23-2025, 01:48 AM
          • Kaar3l
            Samsung QLED QE65Q7FNAT only standby light
            by Kaar3l
            TV: Samsung QLED QE65Q7FNAT
            PSU: BN4400940A
            MB: BN94-12832K
            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
            09-24-2024, 01:35 PM
            09-06-2024, 11:40 PM
