LG 60PV250 Plasma - Horizontal Lines on any input, and when menu is up
  • sg611
    • Apr 2017
    While watching movies/tv, horizontal lines randomly flicker.
    Here is a video.
    Here are some screenshots from the video.
    And here is a picture of the lines when the menu is up and there is nothing plugged into the input.
    Is there anything I can replace to fix this or is the tv just bad?
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 60PV250 Plasma - Horizontal Lines on any input, and when menu is up
    I'd say it's either
    30% buffer fault.
    70% bad panel.
    Try reseating the orange ribbon cables back into the buffer harness. Give them a good clean with alcohol.
    If not you could try replacing the buffers though not a high chance it will work.
    Lines are never a good sign for LCDs or Plasmas.
    • sg611
      • Apr 2017
      Thanks, I'll try cleaning/reseating. I haven't taken off the back of the TV yet, but does this look like the right thing to buy? Seems like a good deal for the three buffers.
      • Hamie
        • Apr 2014
        • 1383
        no the buffers are to the left side of the tv if you're looking at it from the back with the cover off.
        the item youve posted above run along the bottom, they are not the cause of your fault
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • rstrube
          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
          by rstrube
          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
          Hi Everyone,
          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
          Today, 01:37 PM
