Samsung UE/UN55ES6xxx - black screen with backlight on.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UE/UN55ES6xxx - black screen with backlight on.
    Remove the other two caps and check
    • mirokulaz
      • Apr 2017
      • 14
      It is not just the two others. I will have to remove almost all caps.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Well this thread had same problem now repaired. https://www.badcaps.net/forum/showth...057#post743057
        • chrle
          • Sep 2013
          • 158
          • slovakia
          try to disconnect one of two cables going from t-con to driver board,and power on tv
          • croupier36
            • May 2023
            • 20
            • SI
            Hi....sorry to steal the tread....but just got a Samsung UE55ES6100 that works OK...apart the top half of the screen which is dark....
            I guess this is an issue with the backlight...anyone familiar with this model? Do I have to open the panel completely to reach the backlights for testing or are there other ways to make sure/test that the issue is actually there?
            BTW....in this models the backlights are LEDs or?
            Thanks!
            • Diah
              • Feb 2013
              • 6357
              if you upload photo of yours TV screen to show the darkness we can tell you if it BL issue.
              • croupier36
                • May 2023
                • 20
                • SI
                #27
                Adding some photos of the screen....hope it is clearly visible...
                • Diah
                  • Feb 2013
                  • 6357
                  you need to open the cover of the TV and measure with yours DMM with reference to TV chassis the LED+ pins on BL socket at PSU... you have complete raw turn off it could be the inverter ... so need measurements before you do any things ells
                  • croupier36
                    • May 2023
                    • 20
                    • SI
                    #29
                    OK...have taken the measurements....there are 2 connectors (have added the photos below) and the wired pins are marked R+/- and L +/- from 1-4....have put in the range for the pins where the voltage is not constant....fluctuates during the measurement...
                    R1+: 340-365V
                    R1-: 295-320V
                    R2+: 295-320V
                    R2-: 250-275V
                    R3+: 240V
                    R3-: 200V
                    R4+: 200V
                    R4-: 150V
                    L1+: 205-230V
                    L1-: 0V
                    L2+: 250-275V
                    L2-: 205-230V
                    L3+: 105V
                    L3-: 60V
                    L4+: 150V
                    L4-: 105V
                    Hope it is clear enough....
                    • Diah
                      • Feb 2013
                      • 6357
                      OK...have taken the measurements.....
                      such measurements have many error.. this cant be.
                      do it in this way... yours DMM on VDC 250V and measure each group alone like R1+ with R!- R2+ with R2- and so on too for L side. always the + & - for same number.
                      • lotas
                        • Jan 2016
                        • 4555
                        • Russia
                        #31
                        It came out such indications regarding the common land, so no one measures.
                        • croupier36
                          • May 2023
                          • 20
                          • SI
                          #32
                          OK....did the measurements for individual pairs:
                          R1: 20-25V
                          R2: 21-26V
                          R3: 40.7V
                          R4: 39.6V
                          L1: 6-11V
                          L2: 22-26V
                          L3: 24.5V
                          L4: 36.3V
                          The above given measurements in a range are as they were fluctuating during the measurement.
                          • Diah
                            • Feb 2013
                            • 6357
                            R1: 20-25V
                            R2: 21-26V
                            R3: 40.7V
                            R4: 39.6V
                            L1: 6-11V
                            L2: 22-26V
                            L3: 24.5V
                            L4: 36.3V
                            disconnect the socket between power boards and main boards then plug the tv in wall socket .. repeat yours last measurements way.
                            if there are no much different from last reading... post clear focused photo on yours power boards from top and down side.
                            • croupier36
                              • May 2023
                              • 20
                              • SI
                              #34
                              Pairs with 1 and 2 have still fluctating voltages...
                              Pairs 3 and 4 are now all at 60 V each.
                              Photos of the PSU attached.
                              • Diah
                                • Feb 2013
                                • 6357
                                ok. so yours BL are just 2 channel each L1,L2 R1,R2 , this is had shorted LED, the other channel L3,L4,R3,R4 are fine read 60V.
                                you need take out the panel and all filter sheet to have access to the LED BL. also you need to replace all at once to have clean repair.
                                • croupier36
                                  • May 2023
                                  • 20
                                  • SI
                                  #36
                                  OK, thanks!
                                  Will try to open the pannel in the next days....
                                  • croupier36
                                    • May 2023
                                    • 20
                                    • SI
                                    #37
                                    So, if I understood correctly....I have to replace only the 2 LED stripes for the BL?
                                    No need to check/replace anything on the PSU board?
                                    • HTR-Informatique
                                      by HTR-Informatique
                                      02-09-2025, 06:51 AM
                                    • totof
                                      Samsung UE50KU6070 black screen
                                      by totof
                                      I have my TV model UE50KU6070 which I am trying to repair.
                                      BN41-02528A / BN94-10800C motherboard.
                                      If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                      When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                      After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                      09-26-2022, 02:34 PM
                                    • VcemPzd
                                      Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                      by VcemPzd
                                      Hello everyone !
                                      My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                      04-28-2025, 10:14 AM
                                    • x_orange90_x
                                      TCL 50S535 bad tcon or panel issue?
                                      by x_orange90_x
                                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                      03-29-2025, 11:02 PM
                                    • Chrissygizmo
                                      by Chrissygizmo
                                      02-10-2025, 12:33 AM
