Samsung PL51D550 Clicking Noise + No Video/Sound/etc (Brazilian model of PN51D550)
  • ferrao
    • Apr 2017
    • Brasil
    Hello ppl.
    I've a Sasmsung PDP PL51D550 that I've bought on 2012. Two days ago my mother was watching the television and suddenly it lost it's image while keeping the sound on. After shutting down the television and trying to power on again, it simply fails.
    Reading through this forum I've already started some debugging but I'm in a point where I can't define which board is damaged and what should be replaced.
    I've done multiple tests and definitely theres a problem on one or more of those components:
    X-Main
    Y-Main
    Y-Buffer
    Power Supply Board (BN44-00444A)
    During my debugging I've done the following pattern:
    1. With everything connected If I try to turn on the TV I got some clicking noises, and the LED on the Logic Board blinks erractly. It appears to be entering in a reset state, five times in a row, and them it stops.
    2. Unplugged the Y-Main board power cable and the TV only clicks one time. The Logic Board blinks as it's missing Y-Main and/or X-Main boards. Which appears to be correct.
    3. Plugged back the Y-Main board but removed the power cable to the X-Main board on the Y-Main board, since the power connector appears to be daisy chained to the board. Got the same results on the item 2.
    After this test I've came to conclusion that X-Main should be bad. But I've found a strange thing:
    -> I can't get any of the "vital signs". Vs, Va, Vsc and obviously Ve can't be measured with a voltimeter. All stays at zero or near zero. I even had doubts if Vs and Va should be AC or DC, due to this behavior.
    Now I don't know if the Power Supply board is bad, or if the X-Main and the Power Supply board are both bad.
    How can I debug this? I've done some ohmmeter tests on the MOSFETs on the X-Main and on the Power Supply board, and on some of them I got near 0Ohm between the Drain and Source, which appears to be shorted, but I've done this directly on the boards, and not with the components removed, and I'm not even sure if this was right, since on the Power Supply board the FET's near the Vs and Va probes appears to be used as rectifiers for AC/DC conversion.
    Thanks,
    V.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung PL51D550 Clicking Noise + No Video/Sound/etc (Brazilian model of PN51D550
    I believe that if you have shorted mosfets then the set powers down immediately. You need to check all the mosfets for short circuit (even while on the board) and remove them in turn. You can then check them out of circuit to be sure that they are faulty.
    That will just be the start to repairing the set.
    Photo's of your boards would go a long way towards help being provided.
    • B0r1s
      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
      by B0r1s
      PSU - BN44-00878A
      Symptoms:
      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
      A weak clicking sound was coming from the transformer.
      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
      Progress:
      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
      01-17-2023, 04:58 PM
    • slimmy182
      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
      by slimmy182
      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
      Looking on google I found this:...
      01-14-2023, 11:55 AM
    • beetle1303
      Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
      by beetle1303
      I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
      On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
      01-13-2025, 08:49 PM
    • mikelu53
      Samsung UN60D8000YF Clicking BN44-0432A
      by mikelu53
      I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
      The set was working then not,then started clicking.
      Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
      Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
      A schematic or suggestion would be great.
      01-21-2023, 03:14 PM
    • bffargo
      2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
      by bffargo
      LG 60PB66550 NOV 2014
      PSU: EAY63168603
      PCB: EAX65359531 2013.11.01 Rev:1.0
      Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
      Symptom:
      While watching, just went black and started clicking relay every few seconds.
      Initial diagnosis:
      Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
      Deeper diagnosis:
      Pulling pins #1/#2 (Blue/Grey) from the connector housing...
      09-09-2022, 07:34 PM
