Help with Toshiba 32av502r power supply
  • Wbfinley
    • Apr 2017
    • 3
    Hello badcaps community! I am new to the forum but I hope I can become apart of it in time. So I am semi-new to electronics like this. I am tradesman so I have some good fundamental hands on skills but I need your help. I have a Toshiba as per the previous mentioned title that I believe has a power supply problem. I had a power surge in my home recently and this TV was left out of the unplugging party. I have removed the back and it reviled a blown fuse at the AC input on the power supply. I replaced the fuse but when I reattach the 110 cord, even before turning the power switch, the fuse blows, consistently. So as soon as the 110v comes in, the fuse blows. I have not done a repair of this depth in small electronics before but I believe I can follow advise very well. Can anyone point me in the right direction?
    Any help is much appreciated. Thank you!
    I have ( I think) attached an image of the Power supply. The number on it is: 01-pk101v1070i-vapim-917-1216-00a
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Help with Toshiba 32av502r power supply
    I would check the bridge rectifier. The black thing on heat sink with tester in diode beep mode no power hooked up. Across each pair and reverse leads do the same. Meter should not beep. Also you can check across input terminals should be no continuity.
    • Pauldesign
      • Apr 2013
      • 49
      • South Africa
      When ever a fuse blows, it highly possible that it dies with the bridge rectifier (shorted), the short circuit resistor protection (blown), the switching MOSFET as well as the PWM IC driving the MOSFET -- check for shorts using diode or resistance test of your multimeter.
        by sam_sam_sam
        03-31-2024, 02:12 PM
        by sam_sam_sam
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
