Toshiba 50L1350uc no back light
  • nickmatine1
    • Mar 2017
    • 8
    • usa
    this unit has for one second a short flash and after that no picture and has sound
    the voltage is this WITH or WIHOUT connector plugged
    start as 130 v for both l1 and l2 for one second and after is
    L2+ 77DC
    L1+ 77VDC
    measured on chassis ground
    and i repeat with coonector plugged or unplugged (for led)
    any ideas
    thanks
  • nickmatine1
    • Mar 2017
    • 8
    • usa
    Re: Toshiba 50L1350uc no back light
    some pictures
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Is BL_ON/OFF => 2.5V. If it is then it looks initially like an led string problem.
      What's the LCD panel number
      • nickmatine1
        • Mar 2017
        • 8
        • usa
        yes bl-on/off is 3.3 v
        and when the tv open for second
        L2 is 90v and drop to 76
        L1 is 138v and drop to 76
        lcd panel is LC500DUE
        SF R1
        LG display
        thanks
        • dskall
          • Oct 2016
          • 2905
          • usa
          Led problem
          • nickmatine1
            • Mar 2017
            • 8
            • usa
            ok. i'll try to open it and let you guys know
            thanks for your help
            • nickmatine1
              • Mar 2017
              • 8
              • usa
              before start to remove LED
              i put another LED panel from a cracked LG 49LF5900 (this one work good just cracked screen LED panel is china HC490EUN-SLES2-2132) and has the same connector. but still have backlight for one second. tested also with flashlight and has image but still not backlight
              • dskall
                • Oct 2016
                • 2905
                • usa
                Different panel different current draw. Each board is set to work with a certain panel
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Originally posted by dskall
                  led problem
                  The panel is set up with 3 strips of leds each having 10 leds per strip. Running typical voltage of 111V
                  There are 2 of these as show in the attachment.
                  Can you double check L1 & L2 again with the led connector disconnected and see if they initially peak at the same voltage.
                  If they do then I would suspect a led fault along L2 strips.
                  Edit
                  Just re-read the thread. Are L1 & L2 both at 130V at switch on as you say in post #1 or now at the different voltages you say in post #4???
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    by sam_sam_sam
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                    09-06-2024, 05:27 AM
                  • PNI E.
                    tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                    by PNI E.
                    hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                    02-20-2025, 08:36 AM
                    09-06-2024, 05:59 AM
