As the title says, I'm looking for info regarding the Panasonic TCP50S1 and TCP50U1. I have two of the S1's and one of the U1's on the bench right now. One of the S1's had a blown SC and SS but a good panel. The other had a broken screen and a missing SC. The U1 had a broken screen and a dud mainboard. The only difference that I can see between the two main boards is the S1 has two fans driven off the main that the U1 doesn't have. The S1's main works with the U1's other internals. I'd like to sell the buffers from the S1's if they're good but I haven't been able to find a test procedure. They both use the same panel but different SCs, SDs, SUs, and SSs. What's gonna happen if I connect the SU and SD from the S1 to the SC from the U1?
TC-P50S1 vs P50U1 same panel different internals.
Tags: None
Re: TC-P50S1 vs P50U1 same panel different internals.
Test the buffer boards by removing the 4 screws that hold them to the sc board and remove the 3 connections going to the sc(white?). Using a dmm on continuity or beep mode for a short circuit, put neg on one of the floating variable ground pads that you removed the 4 screws from. Lift up the ribbon latches and take pos probe and drag across all the connector pins. I wouldnt try different buffers on sc boards myself. -
If they're the same panel it's unlikely to be an issue. Think of this like a 5081 / 5105.
Cheaper models have cut down boards and buffers with no heat sinks. how you present this though for sale, that's the issue. Can't really say it's a S1, it'll be a mongrel but it will work. Plus all the mounts will be present too for fans etc.Comment
I'm gonna sell the parts on eBay. I've already sold two of the PSU's. There isn't much to be made from a working 8 year old Plasma these days. I might get $150 if I hold out. Then I have to deal with all the asshats out there looking to get it for even less. I'd rather take my chances with eBay.Comment
by NolesFanI have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you06-23-2025, 09:19 AM
by howardc6449UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on... -
by triplefourTV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board.... -
I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....01-13-2024, 01:57 PM -
I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
...11 Photos - Loading...
