Re: Panasonic TX-P42GT20B - Stuck Stby
Before you do this, I would check the buffers are ok, then hook it all up, fire the TV u check it is all good including 3D if you use it.;
Then get a copy of the manual for your model, a copy of the TX-P50G20B or E as that is the model which uses rev AW
Then visually look for differences or compare all C16xxx and L16xxx parts numbers and locations to determine what is the same, what is different.
If you have the boards laid out in front of you you'll start noticing the differences.
I'm not going to work it out for you. I've never done it but it's feasible or return the board and get the correct one
Originally posted by benjamin.d.bird
View Post
