Re: Samsung UN55HU7200 not powering on, no blink code
So, shopjimmy got back to me with a pretty cut and paste "sorry, we don't offer technical support at this time" answer. Oh well, any advice one way or the other before I pull the trigger?
I saw that too. Neither of them have 3d. Which is why you can never trust anecdotal Internet info.Leave a comment:
The other commenter says the un55hu7200 does not have the 3D functionThis guy seems to think they are the same as well:
https://www.amazon.com/difference-be...sin=B00KJEZIEULeave a comment:
I would verify for sure with shopjimmy to see if there is any requirement to do any firmware update if you do use the same original board.
http://www.shopjimmy.com/samsung-bn9...main-board.htm
http://www.shopjimmy.com/samsung-bn9...hu7200fxza.htmLeave a comment:
Hey guys, quick question: the main in my TV (55hu7200) is the BN94-07917A. The cheapest are around 100 on ebay. There is a similar model, the 55hu7250, with a different part number main board, BN94-07777A (though they're both variants of the BN97-08902A circuit board). This board is 70 on ebay. Do we think they're interchangeable?
My previous experience with Samsung models that only differ in a 50 at the end is that they are for different retail outlets (ie Costco) and I successfully used one main board in the other.
What do you guys think?
CheersLeave a comment:
Yessir, same results all around. Am I being hasty by returning the set to SJ? Or should I hold on to it for a few days for testing purposes. Literally everything I've tested is the same.Leave a comment:
Interestingly, there's a small button on the main board in the bottom right (SW1200_DB) that when pressed, elicits a click on the power board. Not sure what it's supposed to do though.
Nothing happens with the speakers, BT, wifi, IR, and then disconnected though.Leave a comment:
what happens with just power cable to to main and nothing else ? do the voltages look correct going to main ?
am wondering if its something silly like a shorted speaker .Leave a comment:
TV with the back off (all the new components):
Main:
Power:
T-con (heat sink/shield off):
Closeup of pinout from PSU to main:
I'll get around to retesting the pins shortly. Still sounds to me like the main I got is crap. I haven't shined the screen with a light, but it's not turning on. There are no relay sounds, no change in the indicator LED, nothing.
Backlights DO come on if you disconnect the ribbon cable between the PSU and main. This is what makes me believe its not a backlight short / issue.Leave a comment:
Maybe the boards you recived came out of a smashed screen set so they may not of been tested properly it does sound like a faulty mainboard still too meLeave a comment:
Check for fuse or vatika resistance ohmLeave a comment:
I think we need to start over with do you get image on screen with flashlight?
Need good clear straight on pictures of back of tv with cover off and each board.
Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
Format:
Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
1 - XXXXXXX - XXv - XXXv
2 - XXXXXXX - XXXv - XXXv
3 - XXXXXXX - XXXv - XXXv
4 - etc.Leave a comment:
I've done that. I get voltage change. I also swapped it out for the new button that came with the kit. At this point I've swapped main, tcon, power, Bluetooth, WiFi, ir receiver, and button. So something has got to be bad, right? It's basically a whole new TV, right? If an LED had gone bad, they wouldn't come on and stay on when testing, correct? I had a bad led in a Sammy before, and it would turn on and turn right back off.
Measure your button connector at mainboard for voltage change when buttons pressed. Have you tried with a remote?Leave a comment:
Hey folks, so, I got sent on a project before I was able to fiddle with this again. While away, I ordered a repair kit from shopjimmy, which included all the boards for a measly 80 bucks. Well, I got back today, and excitedly opened the back of the TV, opened the box, and installed the new main board. Same issue. Perplexed and disappointed, I pulled the cable between the main and power, and the backlights turned on. I then proceeded to replace every component in the TV with the ones from the repair kit. No change in behavior with any component.
So, what do you guys think? The backlights seem fine. Do you think I got a bad main from SJ? They're usually so good.Leave a comment:
So you did the power supply/LED driver board self test by disconnecting the cable between the power supply board and the main board and you get the backlights to come on.
Disconnecting the WIFI did not make any different so it means that there is problem on the main board some where.Leave a comment:
Thanks for the prompt replies. I drove over to work on it. Power board is indeed BN44-00781A main is either BN94-07917A, or BN97-08902A.
Sorry if I wasn't clear before, no readings change when I press the button.
When testing BLU_ON/OFF, I get no reading. I get a negative reading if I put the second probe on UD.
Diconnecting the main and power does indeed turn on the back lights. Testing BLU_ON/OFF turns the back lights off and gives me a reading of about 0.1V (not a digital multimeter). Removing the probe turns them back on.
Diconnecting the WiFi module doesn't do anything. At least, pressing the power button causes no reaction.
I'm on a metered connection right now, I'll get home and post the (terrible) pics of the guts.Leave a comment:
PS-ON is working otherwise he will not have the switched B13V so part of the main power supply is working..
PS-ON and BL-ON are Active HIGH in this TV. See if BL-ON is also stuck HIGH.
Which are your boards?
http://www.shopjimmy.com/catalogsear...ung+UN55HU7200
Disconnect the cable between the main board and the power supply/LED driver board to see if the Backlights will come on and stay on, if it does then you have problem with the main board, which then you can try disconnecting the WIFI module to see if the TV will function.Last edited by budm; 03-01-2017, 10:48 PM.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
