Element ELEFT502 with flickering image (not backlights)
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I am working on Element ELEFT502 that has issue where the screen flickers. It is not backlight related, see video below. It does not matter if the TV cold starts or if it was on for several hours. Every now and then out of the blue, the picture "stabilizes" for second or two, but 99.9% it is like the video shows.
    I have cleaned the connectors, inspected the tab bonds, no change. There is no T-Con board on this set. Would it be a safe bet that the driver boards or gate drivers went south?
    Video of problem: https://youtu.be/KqHD8Z2yN0w
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Element ELEFT502 with flickering image (not backlights)
    Power supply problem...Most likely e-caps need change-out.
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      I have replaced the 10 caps in the upper right corner of the board, still the same issue. Should I try replacing the other smaller caps on the board as well?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        You need to take a look at P2. It may well have a poor connection having been distorted. It could be causing power supply fluctuations. I would lift it out straighten the legs and solder it back in place.
        • Pioneerx01
          • Apr 2015
          • 241
          • US
          Yes, I have swapped that one out as well when I was doing the caps.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Make sure all ground screws tight. Check solder at connectors. Wiggle wires. Seems like connection problem.
            • Pioneerx01
              • Apr 2015
              • 241
              • US
              Yes, that was my initial though, and that is exactly what I did. All connections were cleaned and re-seated. Main power connections were re-soldered. Cables were wiggled and pulled and still no difference.
              I am going to disconnect the PSU from the main board and let it drive the LEDs only. I will use another PSU to drive the main board only and see if that makes any difference. Wish me luck, I have never done this before.
              • Pioneerx01
                • Apr 2015
                • 241
                • US
                So, I tried hooking up external 12V power supply to the main board bypassing 12V source from TVs PSU, but the issue was still the same. I was still pulling 5V from the TVs PSU, I don't have a external 5V PSU on hand right now.
                • cjard
                  Dell U27HM flickering/quarter image/black with smeared colors
                  by cjard
                  Hi all
                  Wondering if I could get some insight on a Dell U27HM. First turned it on and the image was completely black. I later realised that if I dragged a window from one monitor to (the broken) other one then smeared colors would appear on the bottom 75% of the screen. After being on for several hours the top part of the screen started flickering showing an image (I have a video of this) and then suddenly the image appeared albeit rather fuzzy in the bottom 75% - image attached - and some hour later it now appears normal
                  I do have two of these monitors so a compare/swap...
                  09-13-2022, 07:12 AM
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
                • TrueSword88
                  KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
                  by TrueSword88
                  Hi All
                  I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
                  I've reset the unit to factory default & rerun the initial setup but no change.
                  IF I choose any other mode, example: Standard, flickering disappears.
                  I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
                  I've taken the unit apart,...
                  05-05-2023, 06:07 PM
                • dicky96
                  HP Elitebook Screen blank - backlights but no image
                  by dicky96
                  Hi guys
                  I'm trying to fix this laptop screen
                  Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                  OK so I have the original screen which works but has lines across the bottom quarter of the screen
                  I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                  04-28-2021, 07:30 AM
                  HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                  This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                  09-06-2024, 10:56 AM
