Here I Sit, Losing my mind. Haha. Samsung Pn51d550c1fxza
  • Larry420r
    • Feb 2017
    • 27
    Make: Samsung
    Model: PN51D550C1FXZA
    Type: Plasma
    Issue:
    Plug in, Clicks.
    LED Powerlight on front blinks.
    After short time clicking stops.
    Tv is apart. On table. I'm now lost in trying to diagnose this issue.
  • Larry420r
    • Feb 2017
    • 27
    Re: Here I Sit, Losing my mind. Haha. Samsung Pn51d550c1fxza
    if anyone knows how to diagnose how to fix the Xsus if that in fact is the culprit here are attached photos
    I have tones of other parts I can take parts off of.
    first photo there is some damage to back of board not sure if it will effect anything
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      1st picture looks as though it's just a poor solder joint that needs soldering.
      You could use your meter set to ohms and check what resistance you have between the pins of the two white connectors to ground.
      • Larry420r
        • Feb 2017
        • 27
        sorry I'm still extremely green to this, can you be more specific please
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Do you have a soldering iron, also a multimeter and know how to use it?
          • Larry420r
            • Feb 2017
            • 27
            Yes I do have a soldiering iron, also yes I have a multi meter but not 100% familiar with it
            I have attached a picture of the meter, if you are able to edit it and let me know what settings are what, we can move forward and I can try to assess this situation.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Best start with some basic checks.
              With the board disconnected as shown in Picture 2 check the resistance between each pin in turn on the two white connectors.
              Use red meter probe to test pins and connect black meter probe to a GND (Ground) connection.
              I believe there are labels printed alongside the pins.
              Example 5V, VA, VS, RL_ON , GND, etc
              Select 200 ohms range and with the black lead on any of the pins marked GND use the red lead and check all each pin on each of the two white connectors and note the readings.
              • Larry420r
                • Feb 2017
                • 27
                readings:
                1. vs - 3.5
                2. vs - 3.5
                3. ve_in - nothing
                4. GND
                5. GND ( which I'm using for ground)
                6.ERC
                7.Erc
                8. erc
                9. erc
                10.erc
                11. gnd
                12. 15v - nothing
                13. 5v - nothing
                ^-- top white connector
                • Larry420r
                  • Feb 2017
                  • 27
                  Originally posted by Larry420r
                  readings:
                  1. vs - 3.5
                  2. vs - 3.5
                  3. ve_in - nothing
                  4. GND
                  6.ERC
                  7.Erc
                  8. erc
                  9. erc
                  10.erc
                  11. gnd
                  12. 15v - nothing
                  13. 5v - nothing
                  bottom white connector only has 12. and no legend on what is what.
                  • Larry420r
                    • Feb 2017
                    • 27
                    Ps just tested the ERC pins and they read 190.4
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      So the VS pins are showing 3.5 ohms?
                      • Larry420r
                        • Feb 2017
                        • 27
                        this is correct
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          It looks as though you have a short circuit (near enough) on that line.
                          What voltage is VS when you read it off the label from the back of the plasma panel.
                          Can you post pictures of the front and back of the circuit board as attachments (so they are bigger) to view showing the devices mounted on the heatsinks. There's every possibility that one or more may be damaged.
                          You might find this helpful
                          https://www.youtube.com/watch?v=-7zWKY2Hwnc
                          • Larry420r
                            • Feb 2017
                            • 27
                            uploaded
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              The pictures really don't open up to read anything on them.
                              If you set your meter to diode mode ---:>!-- check the devices that are mounted on the heatsinks and look for a short circuit (low reading) between any two pins of each device.
                              • Larry420r
                                • Feb 2017
                                • 27
                                alright will do now
                                • Larry420r
                                  • Feb 2017
                                  • 27
                                  heatsink - 002
                                  (all points)
                                  • Larry420r
                                    • Feb 2017
                                    • 27
                                    if you have skype or anything like that I can download it and install it to make communication easier
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      No, I don't sorry.
                                      Unsolder the ones that read 002 and check again out of circuit. I suspect they are all short circuited.
                                      What are the part numbers written on the devices fitted to the heatsink
                                      When you are not familiar with the set, pictures are worth a thousand words.
                                      Can you photograph the devices fixed to the heatsink.
                                      • Larry420r
                                        • Feb 2017
                                        • 27
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
