Here I Sit, Losing my mind. Haha. Samsung Pn51d550c1fxza
  • Larry420r
    • Feb 2017
    • 27
    Re: Here I Sit, Losing my mind. Haha. Samsung Pn51d550c1fxza
    all the points on the heat sinks read 002
    • Larry420r
      • Feb 2017
      • 27
      the 12 points. ( 4 on each sink )
      on all heatsinks are reading 002 ( when I touch meter to left and right side)
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        You really need to remove them carefully and see if the short circuit has gone.
        • Larry420r
          • Feb 2017
          • 27
          I just finished supper now its reading 001
          so I just unscrew the screw on the mosfets and remove just the heatsink?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I cannot really tell you because I cannot see how they are fitted to the heatsink.
            Normally you can remove them without removing the heatsink. Keep a note of which one was soldered in where. For example Q601 Part No. FP2345, Q603 Part No.AF1123
            • Larry420r
              • Feb 2017
              • 27
              oh I just clued in.... you meant check the readings on the mosfets.
              one sec, I will do that right now
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                I've just noticed that you've posted picture. Missed them because it was on the previous page.
                Check across the pins of each device in diode mode and if the reading is low then you need to unsolder it and remove it. Then check the next device and repeat until you find all the shorted devices.
                • Larry420r
                  • Feb 2017
                  • 27
                  right side heatsink ( singular )
                  Going from top to bottom, 4 in total on this heatsink
                  Top - 364 part -30g124
                  next down - 364 part - auk71514
                  next - 368 - part 30g124
                  last - 368 - part auk71514
                  left top heatsink 4 aswell
                  top- 001 part auk 71514
                  next -001 part rjp30h1
                  next- 864 part auk61317
                  left bottom heatsink 2 mosfets on it
                  top - 001 part rjp30h1
                  bottom - 001 part auk71513
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    The ones the read 001 need to be taken out and checked out of circuit.
                    • Larry420r
                      • Feb 2017
                      • 27
                      the two on the left bottom heat sink are going to be next to impossible to remove without removing everything cause there is caps in the way
                      • Larry420r
                        • Feb 2017
                        • 27
                        removing the caps then gonna pull the mosfets.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          I have a small right-angled ratchet screwdriver for getting into limited spaces.
                          • Larry420r
                            • Feb 2017
                            • 27
                            k just finished getting all 4 out and the caps out.
                            testing right now
                            • Larry420r
                              • Feb 2017
                              • 27
                              top- 001 part auk 71514 -- new reading 370
                              next -001 part rjp30h1 -- new reading - 002
                              top - 001 part rjp30h1new read - 002
                              bottom - 001 part auk71513 - new read 362
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #35
                                Are those readings taken of the components after they have been removed from the circuit board.
                                Any of the devices which still measure 001/002 out of circuit are faulty.
                                If you measure VS to ground with your meter set to 200 ohms, has the low resistance you gave earlier now gone?
                                It's late here so I'm off for the night.
                                • Larry420r
                                  • Feb 2017
                                  • 27
                                  not getting anything now on the meter.
                                  • Sevenqi
                                    • Jul 2011
                                    • 292
                                    #37
                                    Normally the following MOSFETs were damaged, replace them all, you need to remove the nearby caps before remove them.
                                    1. Remove related caps (c4702,c4703, green color) so you can remove RJP30H1.
                                    2. Remove the following MOSFETs (Most likely they all shorted)
                                    Q4202 (30G124)
                                    Q4503(30G124)
                                    Q4101(30G124)
                                    Q4104(30G124)
                                    Q4301(RJP30H1)
                                    Q4302(RJP30H1)
                                    3. Measure if still any short, if yes, please check the following diodes:
                                    D4202(SF10A00H)
                                    D4505(SF10A00H)
                                    D4103(SF10A00H)
                                    if they were shorted, replace them with good ones.
                                    4. Replace the 30G124 and RJP30H1 with good ones.
                                    5. Now there shouldn't have any short, install the x-main to the TV.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      I'm not familiar with this set but if the Xmain, which we know is damaged, is connected across to the Ymain, then I would check that there are no short circuit components on the Ymain board before refitting the repaired Xmain.
                                      I would also take Sevenqi's advice and change all the Mosfets and diodes he listed.
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8325
                                        Here is my run in with the X-Main, if that's any help:
                                        https://www.badcaps.net/forum/showthread.php?t=57039
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
