Eeprom dump thread!
This is a sticky topic.
    Looking for Blaupunkt 32/133-WB-5B2-HBKUP-EU flash ic UF11 dump
    Model ref:B32A133TCHD
    Main: TP.MSD309.BP85 C12415
    Screen: LC320DXJ SFE1
    I have the dump for the lsc320an02 screen but unsuitable.
      Hello, I sent you a link to the dump you asked for in a private message. You could also try to fix your non-working dump
        Thanks for the above file
        Looking for Bush 24/207FDVD-S flash ic UF11 dump
        Main: T.MSD309.B66B
        Screen: BOER236WU1
        I have the dump for the Bush 24/207F attached but would like to get the DVD going as well for it.
        Attached is the corrupted dump and the Bush 24/207F both with the same screen
          Hi i have a polaroid p40led14 using the 17ips20 power board the 17mbb2s mainboard and a ves400unds 2d r06 lcd the issue i have is it will come out of standby but nothing on screen could this be a firmware fault
          Edit, please ignore above, the set has one failed led on one strip.
            Originally posted by vinceroger69 View Post
            Hi i have a polaroid p40led14 using the 17ips20 power board the 17mbb2s mainboard and a ves400unds 2d r06 lcd the issue i have is it will come out of standby but nothing on screen i have tested the leds they stay lit a 122v on led tester could this be a firmware fault
            Edit, please ignore the set has one failed led strip.
            Anything is possible, first you need to check whether 12 volts is supplied to the t-con board (whether the fuse is live) or whether this happened after an incorrect update (another panel).
              Thanks lotas i will remember too check that next time, not sure if youve seen my edit above the set had one failed led on one strip when taking the tv apart found the set had been dropped as loads of plastic cracked etc so i have stripped the tv for parts (was a free set anyway)
                Need emmc dump for XBR-65X850D or for 55” version, board number is 1-980-832-11, this is USA board and Europe and UK board has same board number but board is slightly different and the dump didn't work so really need the correct one, I don't mind looking after the person with the dump
                  Hi!
                  TV Toshiba 55U6763DG
                  Main: Vestel 17mb120
                  SPI: MX25L1606E
                  Problem: Do not turn on, flashing red/green standby, Unable to make USB update.
                  Can you check and repair (if it needs to be repaired) this SPI dump.
                  Thanks!
                    Originally posted by ivblgrpet View Post
                    Hi!
                    SPI: MX25L1606E
                    Thanks!
                    Try this dump.
                      Try this dump.
                      Thank you for very fast reply. I'll try it on monday and report results.
                        Try this dump.
                        Unfortunately this dump didn't help. Same problem remains. Thank you anyway. Maybe or probably problem is not in MX25L1606E.
                        CH341A is my only tool for programming. I have the UART log. Maybe you can identificate the problem with the help of this log?
                          You have a problem with NAND flash.
                            Ok, thank you
                              hi, i am looking for the eeprom for my Samsung UE40MU6405 -BN41-02568B / BN94-12398F.
                              The tv doesn't power on (power led always off). Backlight on when moherboard disconnected.
                              Non-working dump here.
                                There is no need to search, other people's dumps will not help you, just restore your own one. Try it.
                                  Try it.
                                  It doesn't work, what also doesn't work?
                                    Hello.
                                    I have just tried now and it works very well now.
                                    Thank you lotas :-)
                                      Hello.
                                      Thank you lotas :-)
                                      Well, great that it works!
Name:	Toshiba update via USB.jpg
                                        Tv stuck on Toshiba Splash screen.
                                        Guys here is the Software provided by Toshiba. ## Can someone help as I keep getting - Error: PHP Max Post Size has been exceeded. when trying to upload zip file, thanks ##
                                        Toshiba: 55T6863DB
                                        Mainboard: 17MB130S - 23495635
                                        Panel number: VES550QNYL-2D-N01
                                          SMDFlea commented
                                          Editing a comment
                                          Splitting the attachment might fix that
                                        ok will try that now, Thanks
