samsung ue46es6140
  • mr2013e
    Elc. Engineer
    • Jul 2013
    • 41
    • TURKEY
    samsung ue46es6140
    hello.
    i have samsung ue46es6140 led tv.it is not working.when push power on button screen like this in only 1 sec.(for 1 sec backlight coming and some hor. lines at the top)
    what is the fault.
    i think power supply ok.?? after 1 sec. black screen and backlight is little bit dark.tcon board has 13v
    here is the voltage between power supply and main board.
    pin ??? volt
    1 odlevel 3.8v
    2 dım
    3 odonoff 3.8v
    4 dim
    5 gnd 0v
    6 dim
    7 b13v 13v
    8 dim
    9 b13v 13v
    10 b13 13v
    11 vamp 10v
    12 bluonoff
    13 b13v 13v
    14 gnd
    15 gnd
    16 gnd
    17 b5v 5v
    18 a5v 5v
    19 b5v 5v
    20 poweronoff 3.2v
    here are the pictures.
    thanks for your help( excuse me for my english )
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: samsung ue46es6140
    If you disconnect the main board do the backlights come on.
    • mr2013e
      Elc. Engineer
      • Jul 2013
      • 41
      • TURKEY
      when the cable between main bord and power supply off ,tv on when plug the ac cable backlight works normal.(no button using at this time)
      i think the main board fault.???
      what is this? this is main board's label.my tv ue46es6140. tv is 46 '' but main board label ue40d6500vsxzf (pic2)
      is it not original main board??
      • mr2013e
        Elc. Engineer
        • Jul 2013
        • 41
        • TURKEY
        bad news for me.this tv samsung eu46d6500.exchanged back label.and my fault is panel.
        thanks for all.
          09-07-2024, 05:50 AM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
        • elpatxi_bcn
          Samsung HG75EJ690UB Hotel TV, change main?
          by elpatxi_bcn
          Hello!
          I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
          Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
          The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
          05-19-2023, 03:21 AM
          09-06-2024, 11:40 PM
