Samsung UN55D6003SFXZA Not Displaying
  • notaguitarhero
    • Nov 2016
    • 16
    Hey everyone, I've got a Samsung TV UN55D6003SFXZA that is not working. If I unplug the TV from the outlet, wait a few minutes, and plug it back in, the startup screen ("Samsung SMART TV") appears on the screen for a second before the screen goes dark. At the same time, the standby light blinks 5 times. And then if I try to press the power button, the standby light blinks once each time.
    I disconnected both the main board AND the LED connections, and noticed the voltages at the power supply pins cycle up and down - is this supposed to happen? There seems to be a sound (sounds like a cricket, if that helps) coming from TM801S every 4 seconds or so, and after 90 seconds or so it stops making that sound. After disconnecting the power, the sound continues a few times before stopping. Does this mean the power supply board is bad?
    Any help I can get would be great! I'm giving this one last chance before I take it apart and sell for scrap parts.
    Here are the voltages with various configurations: with only the main board disconnected, everything hooked up, and with both main board and LED disconnected.
    CNL802 (connection to LED)
    With only the main board disconnected:
    Pin 1 (VF+) = 325VDC peak, 322VDC steady state
    Pin 3 ( - ) = 162VDC peak and steady state
    Pin 5 ( + ) = 162VDC peak and steady state
    Pin 7 (Dim-) = 1.1VDC peak and steady state
    Pin 9 (IF2) = 0.6VDC peak and steady state
    Pin 10 (IF1) = 0VDC steady state
    With everything hooked up:
    Pin 1 (VF+) = 328VDC peak, 297VDC steady state
    Pin 3 ( - ) = 200VDC peak, 177VDC steady state
    Pin 5 ( + ) = 210VDC peak, 177VDC steady state
    Pin 7 (Dim-) = 90VDC peak, 62VDC steady state
    With main board and LED disconnected:
    Pin 1 (VF+) = 400VDC peak, drops in voltage, goes back to 400VDC after every other sound.
    Pin 3 ( - ) = 0.001VDC
    Pin 5 ( + ) = 0.001VDC
    Pin 7 (Dim-) = 0VDC
    Pin 9 (IF2) = 0.6VDC peak, drops to 0VDC, goes back to 0.6VDC after every sound.
    CNL803 (connection to main board)
    Pin 1 (N.C.) = 0VDC
    Pin 2 (N.C.) = 0VDC
    Pin 3 (B13V) = 12.74VDC
    Pin 4 (EPWM) = 3.209VDC
    Pin 5 (B13V) = 12.74VDC
    Pin 6 (N.C.) = 0VDC
    Pin 7 (Vamp) = 16.41VDC
    Pin 8 (BLU_ON) = 3.005VDC
    Pin 9 (Vamp) = 16.41VDC
    Pin 10 (GND) = 0VDC
    Pin 11 (GND) = 0VDC
    Pin 12 (GND) = 0VDC
    Pin 13 (B5V) = 5.37VDC
    Pin 14 (A5V) = 5.37VDC
    Pin 15 (B5V) = 5.37VDC
    Pin 16 (PS-ON) = 3.359VDC
    Pin 1 (N.C.) = 0VDC
    Pin 2 (N.C.) = 0VDC
    Pin 3 (B13V) = 12.71VDC
    Pin 4 (EPWM) = 0.007VDC
    Pin 5 (B13V) = 12.71VDC
    Pin 6 (N.C.) = 12.66VDC
    Pin 7 (Vamp) = 18.88VDC
    Pin 8 (BLU_ON) = 0.14VDC
    Pin 9 (Vamp) = 18.88VDC
    Pin 10 (GND) = 0VDC
    Pin 11 (GND) = 0VDC
    Pin 12 (GND) = 0VDC
    Pin 13 (B5V) = 5.35VDC
    Pin 14 (A5V) = 5.36VDC
    Pin 15 (B5V) = 5.35VDC
    Pin 16 (PS-ON) = 3.30VDC
    Pin 1 (N.C.) = 0VDC
    Pin 2 (N.C.) = 0VDC
    Pin 3 (B13V) = ~15VDC peak, drops almost to 0VDC, goes back to ~15VDC after every sound.
    Pin 4 (EPWM) = 2.9VDC peak, drops almost to 0VDC, goes back to 2.9VDC after every sound.
    Pin 5 (B13V) = ~15VDC peak, drops almost to 0VDC, goes back to ~15VDC after every sound.
    Pin 6 (N.C.) = 0VDC
    Pin 7 (Vamp) = ~16VDC peak, drops almost to 0VDC, goes back to ~16VDC after every sound.
    Pin 8 (BLU_ON) = 2.7VDC peak drops almost to 0VDC, goes back to 2.7 VDC ater every sound.
    Pin 9 (Vamp) = ~15VDC peak, drops almost to 0VDC, goes back to ~15VDC after every sound.
    Pin 10 (GND) = 0VDC
    Pin 11 (GND) = 0VDC
    Pin 12 (GND) = 0VDC
    Pin 13 (B5V) = ~3VDC peak, drops almost to 0VDC, goes back to ~3VDC after every sound.
    Pin 15 (B5V) = ~3VDC peak, drops almost to 0VDC, goes back to ~3VDC after every sound.
    Pin 16 (PS-ON) = 2.6VDC peak, drops to 0.9VDC, goes back to 2.6VDC after every sound.
  • Nicktronic
    Sony XBR-55X900F No picture, no sound no backlight
    by Nicktronic
    Hey,
    I have this subject TV and when I plug it in I don't get a picture, backlight or sound. The remote and power buttons don't seem to do anything. I've metered the signals on the following after plugging in the TV;
    Power Supply Board Connector CN6401 between PSU, MB, TCON
    PIN 1 - BL_ERR - 0VDC
    PIN 2 - BL-ON - 0VDC
    PIN 3 - POWER_ON - 3.47VDC
    PIN 4 - N/C
    PIN 5 - STANDBY3.3V - 3.50VDC
    PIN 6 - N/C
    PIN 7 - GND - 0VDC
    PIN 8 - GND - 0VDC
    PIN 9 - N/C
    PIN 10 - REG12 - 12.69VDC
    PIN 11 -...
    04-15-2023, 04:41 PM
  • lapfix
    Dell latitude 5320 South peak 13 not power on.
    by lapfix
    Hello friends
    Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
    motherboard south peak 13 mb 213252-1
    i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
    i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
    As i undestand from many topic here ,...
    04-29-2025, 06:22 AM
  • jaroslav.psenicka
    Apple MBP A1398 EMC 2881 No backlit, PP3_G3H drops to 10.8V after start, 0V on LVDS pin 1
    by jaroslav.psenicka
    I have a MBP A1398 EMC 2881 here, it chimes, boots and shows picture on external screen
    there is an apple logo on the display, no backlit
    I measured the PP3_G3H on the backlit fuse - it's 12.6V when not powered and it drops to 10.8V after startup.
    Is this OK?
    Also measured the LVDS connector pin 1, there is 0V, could that be the backlit driver chip?
    Also checked all 4 "backlit" capacitors, all OK, not shorted.
    Thank you very much,
    -jp
    12-02-2024, 01:29 PM
  • Green Probe
    Latitude 5530, 203102-1, South Peak 15 MLK MB DDR4, i5 12th Gen
    by Green Probe
    Hi, I'm looking for a schematic and/or boardview for a Dell Latitude 5530. The motherboard is marked "South Peak 15 MLK MB DDR4, 203102-1, FK8VG$LA" I think it's the i5 12th Gen. I'm trying the similar 5520 schematic, but things are shifted around, making it a bit tough for me to find things. This might not be the place to discuss the issue, it shows no life. It consumes 5V1A when plugged into the USB-C charger. Main rail is present at 16.75V, and 4.2V is present at some locations. Any help is appreciated. Thanks!
    08-15-2024, 05:47 PM
  • SeaglassPearl
    Vizio E420VA 5v drops to 3v when power cable is connected
    by SeaglassPearl
    Folks, I have a Vizio flat screen that doesn't show any signs of life (and no orange vizio glow either).
    I tested the voltages from the power board (at the connector) and I can see the 5V supply drops to 3V after the power cable is connected to the main board (5V supply reads as 5V when cable is disconnected from main board). All other rails (12V and 24V) are reading fine.
    I looked for the usual bloated caps and saw none on either board and no other tell-tall signs (black marks, burned components, etc) on either side of both boards.
    Given the 5V rail...
    12-30-2022, 05:55 PM
