Samsung PS51E6500 Issues
  • qweasdzxc
    • uk
    Hello, I have a Samsung PS51E6500 Plasma TV. It stopped working while watching a 3D movie. The screen turned black, the SmartTV logo came up for about half a second. The screen stays completely black and it doesn't react to anything, including changing channels, opening the menu, etc. The sound, however, does work. When the TV is turned on, there is a slight glow for about 2 seconds, after which the screen turns completely black.
    I checked the Va and Vs voltages. They are correct and do not fluctuate. The logic board has a green blinking light that blinks at a pace of 1 a second. I checked the y buffer board with a multi-meter and as far as I can tell, none of the chips are short-circuited. I ran the PAL test successfully by connecting the 2 pins on the logic board. The y board seems to be working because when I plug it out from the logic board, the logic board reports an error (one blink per 5 seconds).
    It sounds as though this is a problem with the main board because everything else seems to be working fine, however, I can't find a test online specifically for the main board. I am wondering whether there is something I have missed out.
  • milan156
    • uk
    Re: Samsung PS51E6500 Issues
    I had a similar issue. I had the TV unplugged for about two weeks. When I had time to look at it again, it worked fine!
    • ohren
      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
      by ohren
      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
      The models launched in 2018 and 2019 respectively....
      09-08-2023, 05:24 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
      09-07-2024, 05:50 AM
