Trying to fix this 2010 Panasonic Plasma for a friend . I am an experienced technician, but not so much in plasma TVs, this is just for the fun and challenge.
Hoping for some advice here.
Symptom :
When powering the TV ( power button on the A-board engaged ), a green LED flashes rapidly for a second, the relay clicks - after a second it clicks again -then repeatedly 10 red blinks.
What I have done :
- The F+15V is present P6/pin7 between the clicks of the relay (14.75V )
- The P+15V is present P25/pin1 between the clicks of the relay (15.7V)
- The Vda is present P35/pin1 between the clicks of the relay (60.5V)
- The Vsus is present between the clicks of the relays ( 208V )
- Various SUB voltages on A board OK as long as +15V is present
LED_6V DET on IC1100 on A-board is HIGH
FRC+3.3V DET on IC1100 on A-board is HIGH
MIHO+3.3V DET on IC1100 on A-board is HIGH
SUB+5V DET on IC1100 on A-board is HIGH
SUB3.3V DET on IC1100 on A-board is HIGH
Using the " 2010 - FHD Plasma TV Troubleshooting handbook" i tried :
- Startup without SC20 connected - still 10 red blinks !
Then I purchased a (used) A-board
- Absolutely no change, still 10 red blinks
Other observations (all connectors in place ):
SOS6 from SC board goes HIGH due to Vmid being only 52V ( should be 60-150V as I read it )
SOS8 from SS board goes HIGH due due output being only 29V (TPSS1)
Also tried to dismount D25 LVDS cable, no change.
Now, I have a SS board on the way ( longshot !! )
Any input / advice ?
I could of course have TWO A-boards with the same error - but seems unlikely.
Since the SC/SU/SD boards hav been isolated these should not be at fault - also checked common shorts on SC board - seems fine.....
Yes, I have read the forum ( and half the internet... ) about "10 red blinks" - but most posts seems to relate to older plasmas, with older chassis...
I can of course measure / check anything - any help appreciated and welcomed
