Sony KDL-40VL160 T-Conn or LCD
  • krumian
    • Nov 2016
    • 6
    I have this Sony TV that I purchased in late 2009. I started getting horizontal lines one one side of the screen and the other side is all black. If I disconnect the T-conn then I get white. The TV stays on and if I recall the red LED blinking sequence, I get 14 blinks. I've read that this could be either the T-conn or the LCD itself. I'd appreciate any feedback. Thank you.
  • krumian
    • Nov 2016
    • 6
    Re: Sony KDL-40VL160 T-Conn or LCD
    Any advice? Thank you.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      If you disconnect LEFT side cable of T-CON Bd to Panel but leave the RIGHT side cable connected and power ON TV...What do you get on the Right side of the Screen??....AND....if you reconnect the LEFT side cable and disconnect the RIGHT side cable and power ON TV...What do you get on the Left side of the Screen??....
      • krumian
        • Nov 2016
        • 6
        I am out of town right now but I remember when doing that, I would get a white half of the screen. I just don't remember if the white half was on the side I disconnected or on the opposite side. I'll check when I'm back in a few days. Thank you.
        • krumian
          • Nov 2016
          • 6
          So I tested the screen and as I thought, the side of the t-con that I disconnect goes white. As soon as I reconnect, the lines come back. Any suggestions? Thank you.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Is that for both sides??
            Measure and report these voltages on your T-CON Bd. In brackets are what you could expect.
            Vcc (5Vo12V) on both sides of the fuse F1
            Von (20V~30V) may see it as VGON,VGH, VDDG
            Voff (-5V~-8V) may see it as VOFF, VGL, VEEG
            Vdd (3.3V) may see it as VLOGIC, VDDD, DVDD
            Vda (13V~20V) may see it as AVDD, VDDA, V Source
            If these voltages are OK you have a bad Panel. If they anot good, try a new T-CON Bd.
            • Watson306
              6 Red Blinking lights (left side darker) on Sony KD-49XE8396
              by Watson306
              I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
              I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
              I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
              Many Thanks in advance.
              11-01-2022, 05:33 AM
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
            • ptcriserx3
              Sony trinitron crt bowed and side color issues
              by ptcriserx3
              Hi
              Ive got a vintage 2001 sony trinitron flat tube tv
              The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
              See many images attached...
              Just windering if this is not fixable or something i can correct without getting too invloved
              Im trying to sell the tv
              06-17-2023, 07:27 PM
            • flibidy
              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
              by flibidy
              I have here a Magnum IA.100 which belongs to my parents.
              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
              What Ive done........
              01-01-2025, 01:26 PM
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
