HikVision DVR
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    HikVision DVR
    Dear all,
    does anyone have a diagram or schematic for motherboard of any HikVision DVR device that shows motherboard's circuit?
    thanks in advance.
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • SilverbackITGuy
    Asus ROG Strix G17 , Identifying a part number from the boardview diagram ID
    by SilverbackITGuy
    First of all, I hope I got this into the right section. Apologies if I did not.
    I was working on my Asus ROG Strix G17 (2021) G713QM-RS96, and I guess I pre-heated the board too much replacing the DC Jack and one of the small parts came off. I looked for it on my soldering mat, and it was nowhere to be found. So now, the laptop is powered from the new DC Jack I installed, but it will not charge the battery from that jack. Only powers the hardware.
    I looked at the boardview diagram in another post for the G713QM, and it looks like the diagram displays it as X450, a 4 contact...
    11-18-2025, 07:23 PM
  • gabri2211
    I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
    by gabri2211
    hello everyone, I'm looking for the wiring diagram of this led monitor.
    the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
    I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
    I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
    thanks to those who will answer
    12-10-2024, 04:37 PM
  • Rauni
    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
    by Rauni
    Hello, this is my first post on this forum, and my first attempted to repair a TV.
    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
    Read also that we should test what happens if we...
    10-01-2023, 12:06 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
