Toshiba LCD TV model 40L3455DB backlight issue. (Vestel 17IPS20 power board)
  • Ianhw77k
    • Nov 2016
    • 14
    This TV was fine until the other day, we went to turn it on and nothing happened. I eventually found out we had sound but no picture, then did the flashlight test and diagnosed a backlight issue.
    I've tested the main power board voltages to the LEDs, the black wire is giving 11.3v and the red wire is giving 116.6v after first starting at around 190v and settling down to the 116.6v.
    Is it time for me to start dismantling the set further and test individual LEDs or should I be doing further testing?
    Go easy on the terminology please, I'm a mechanical engineer so you'll need to explain things to me like you would to a child.
    Thanks in advance for any help.
    Ian.
  • Ianhw77k
    • Nov 2016
    • 14
    Re: Toshiba LCD TV model 40L3455DB backlight issue. (Vestel 17IPS20 power board)
    Upon closer inspection I've just counted 45 LEDs so maybe 116.6v isn't right?
    • sordids999
      • May 2013
      • 2152
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      but it does sound like a backlight issue
      • Ianhw77k
        • Nov 2016
        • 14
        I've found a couple of suspect LEDs on two of the strips. I will hopefully try the bridging method of repairing them (if I can find suitable replacements on ebay) and I guess we'll see where I go from there.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Well if you did some research you would know that 190v collapsing to 120v means the driver started but shut off meaning failed Led. Watch my video:
          https://m.youtube.com/watch?v=RxwdC7V5Ue0
          • Ianhw77k
            • Nov 2016
            • 14
            Yes, I've watched that video twice now, so I'm on the right track.
            I've removed 3 LEDs, I just need to find suitable replacements but I'm finding the numbers a bit confusing. If I can figure out how to upload pics from mobile, I'll put some up.(I'll read through the relevant stickys now)
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              That model uses C type Led I believe, message a bloke on here called Flocko he sells the Leds ready for stacking
              • Ianhw77k
                • Nov 2016
                • 14
                Hoping the images are here.
                • Ianhw77k
                  • Nov 2016
                  • 14
                  Great, I'll see if I have the message function yet and get on with that.
                  Thanks a lot.
                  • flocko
                    • Nov 2012
                    • 1121
                    Hi check out my eBay listing 252574390471 you will find what you need there (Vestal type D in the listing ) have also replied to your PM
                    • Ianhw77k
                      • Nov 2016
                      • 14
                      Just ordered them, thanks for the quick reply.
                      I also ordered some of that silicone heat glue stuff, I've got some old bathroom sealant lying around in the workshop but thought I'd better do this semi properly.
                      Fingers crossed I can get this all back together without breaking anything and it'll work. I'll let you all know either way. Thanks for the help.
                      Ian.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Awesome work keep us updated.
                        • Ianhw77k
                          • Nov 2016
                          • 14
                          I fitted the LEDs, tested them and their connections and all seemed fine. I've partially put the TV back together, plugged it in and it still doesn't work.
                          One thing is different, when it first turns on, the backlight comes on for a split second but doesn't stay on. The LCD display is still working with the flashlight test.
                          Any ideas where I go from here?
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Are you sure you connected those LEDs in the correct polarity direction?...
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              +1 or didnt short out the contacts ?
                              • Ianhw77k
                                • Nov 2016
                                • 14
                                Absolutely, checked, double checked and checked again.
                                Will the backlight flash if there's any connected wrong or any more that have blown? I never got a flash off it before, which leads me to think I'm heading in the right direction.
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  sound like you still have an LED out, or a problem with the string driver on the back of the power board. you can run the backlights without the LCD fitted just leave the T.con ribbons unplugged. you can also test each strip of nine LEDs with 3X 9v batteries in series giving 27v
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    Well it may flash on for a brief moment then shut down if something is shorting somewhere on the connections you made or the new strips shorting the old connections....check...insulate...double check polarity connections
                                    • Ianhw77k
                                      • Nov 2016
                                      • 14
                                      OK, I've stripped it again and one of the replacement LEDs is out. It was fine when I got it as I tested them all. I'll try removing it and testing it again, see if my connections have gone wrong.
                                      Looks like the kids won't be getting their film night tonight.
                                      • Ianhw77k
                                        • Nov 2016
                                        • 14
                                        Turns out that LED was fine, my soldering must have been at fault. I soldered it back in, put it back together and still getting the same problem. Just in the process of stripping it again to test the LEDs.
                                        • ResetReality
                                          Toshiba/Vestel 58UL2B63DB Wifi Issue???
                                          by ResetReality
                                          Hello fellow tech heads.
                                          Had this tv come in...issue stated reboots on wifi.
                                          Indeed it does. However, with wifi off or using cat 5 cable no reboot issues.
                                          So far ive changed mainboard and wifi module...also reset tv back to factory via service menu (4725)
                                          Still same issue... i do have a psu to swap but cant see it being that really as works flawless if wifi is disabled
                                          I thought fireware? But why only on wifi?
                                          Is it an issue with the memory cache filling up and having to reboot for more ram??
                                          At a total...
                                          07-04-2024, 12:28 PM
                                        • psdavid65
                                          Toshiba 40L1333DEV Vestel 17IPS20
                                          by psdavid65
                                          Quick Question Please.
                                          Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
                                          All other components on this vestel board have valid readings except for this U202 IC.
                                          09-21-2023, 12:29 PM
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
