Another Samsung power/inverter board BN44-00264B Rev1
  • jurgyman
    • Jul 2015
    • 27
    So I have a Samsung LN40B630N1FXZA made in 2009
    Its power and inverter board is all in one:
    model: H40F1_9DY
    CodeNO: BN44-00264B
    PCB REV: Rev 1.0
    Date: 08.12.08
    Symptoms:
    Tv Has standby power.
    Tv will power on, can hear startup chimes.
    may see backlight flash on then off.
    if fresh fuse is in, it will fry.
    Frying fuse is in FI801S
    Caps all look fine.
    I have tested components in circuit.
    They all look good except for:
    - QI804 FET is shorted (says on it: K3568 8:m)
    - Di806 diode is shorted (says on it: SSF)
    - FI801S fuse will burn, as mentioned (says: T3.15A/250V)
    So am looking for the schematic of this board.
    to identify those components...
    To potentially buy (where and how?)
    Also I suspect one of my backlights is out/bad/shorted.
    Is there a way to disable the protection circuit on the bad one.
    Is there a way to deduce which is the bad one?
    Not really wanting to take it apart all the way to the backlights...
    See my attachments.
    thanks in advance!
    JurgyMan
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Another Samsung power/inverter board BN44-00264B Rev1
    Looks like the inverter transformers are a problem on these boards
    https://www.badcaps.net/forum/showth...ht=bn44-00264b
    • jurgyman
      • Jul 2015
      • 27
      How does one test a transformer with your typical digital multi-meter...
      Anyone any suggestions on howto to identify the parts that tested bad?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Set your meter to ohms. Primary windings are probably low resistance of just a few ohms and secondary resistance of 1K - 2K.
        Compare the readings you get off each transformer and see if any of the readings do not match the others.
        • doughala
          • Oct 2018
          • usa
          I am looking for the capacitors for cp801 and cp803 value and parts plus power board fuse
          BN44-00264B / H40F1_9DY board
          • doughala
            • Oct 2018
            • usa
            BN44-00264B Rev1
            • R_J
              • 9625
              The values are marked on the caps, (likely 82 uf/450v) the fuse value is marked on the board. (there is more than one fuse)
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Originally posted by r_j
                the values are marked on the caps, (likely 82 uf/450v) the fuse value is marked on the board. (there is more than one fuse)
                +10
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
