Lnt4069fx/xaa
  • exverse
    • Oct 2016
    Lnt4069fx/xaa
    I have a Samsung LNT4069FX/XAA. The backlight and everything turns on but the screen slowing like warms up white, after about 30 minutes of it warming up i turn it off and then back on and it then shows video. I cant find any schematics for the FRC or the Main Board. I tested voltages on the Power Supply and everything checks out via the labeled voltages on the back of the board. Anyone have any ideas?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Lnt4069fx/xaa
    Have you read through:-
    https://www.badcaps.net/forum/showthread.php?t=21422
    • Capacitorial
      Powersupply has all the voltages - Monitor still no power
      by Capacitorial
      Hello guys,
      I have a Philips 240B7QPJEB. The monitor seems completely dead.
      I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
      On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
      The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
      The weird thing is, that the Power LED is powered over the TCON board.
      On The TCON...
      12-28-2024, 02:12 PM
    • gjgib
      Help reading schematic voltages input/output
      by gjgib
      Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
      I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
      I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
      I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
      05-06-2024, 08:11 PM
    • RossMoodley1967
      HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
      by RossMoodley1967
      Hello
      Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
      Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
      03-01-2024, 06:07 AM
    • karlp028
      MSI Z390-A PRO missing VCORE voltages
      by karlp028
      I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
      06-23-2025, 01:25 AM
    • lol999
      Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
      by lol999
      Motherboard after starting show Q code 00.
      No shorts on any rail ( at last I can't finde any)
      All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
      Nothing get hot, PSU starting, all lights came ON....
      One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
      After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
      This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
      01-21-2024, 02:25 PM
