Sanyo DP50749 Power cycle
  • lordsecs
    • Jan 2016
    • 5
    I have a Dp50749 that is power cycling every 15sec. Green power light on no screen for 15sec the relay clicks and repeats. No change with Y sustain or Z sustain boards unpluged.
    When the LVDS cable is unpluged from the logic board set powers on and green power light stays on. Is this a faulty logic board or the main board? Any help will be appreciated
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sanyo DP50749 Power cycle
    The problem on the main board is corrupt IC 5750A flash nand under shield. Available on ebay
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • nono34
      Hisense stuck in Colors cycle like test pattern.
      by nono34
      I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
      I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
      10-24-2024, 04:31 PM
    • Yoda79
      Samsung ue55nu7021k Boot cycle
      by Yoda79
      Hi, wondering if anyone can help with a tv which seems to turn on but turn off soon after and continue to do this cycle over and over again.
      It turns on, no sound and then turns off and starts the whole cycle again. I've opened up the back and can see the backlights turning on. However when I disconnect the two straps connecting the left hard board (as you look on the back of the TV), the boot cycle stops and it does turn on and I can hear the boot up sound, however no video?
      Any thoughts, any help would be greatly appreciated.​...
      06-30-2024, 03:43 PM
    • willoriker
      motherboard power cycle MAX VI Gene
      by willoriker
      hi to everybody
      i have a asus maximus VI gene with a power cycle, i made a lot of diagnostic, but i could found the problem
      i check power sequence, all power source ( 5. 3.3 1.5 1.05, 3.3 cpu vmr) every is ok
      without accesories ( no proc no ram nothing) mother start and keep working
      when i insert cpu, mother boot up, post secuence start .. for 4 second post card show tipical info, and the power cycle begin.
      some behavior . start post and restart. i test, replace bios with difernte version..... NOthing
      try difernt powe supply, porcessor, anbd memories....
      05-16-2023, 03:34 AM
