Finlux 32h7072-no backlight
  • Bizzy80
    • Aug 2016
    • 5
    • United Kingdom
    I have a Finlux 3d model 32h7072-dt and last night when i was watching a tv program the screen went off.
    The tv starts,has sound and picture(when i look very close i can see it) but no light on the screen....everything else works...if i press menu i can (barely) see it
    When i start the tv sometimes it has backlight light for a second or so....sometimes i can see it's connected to hdmi1....I have minimum to medium knowledge about electronics...someone can help me...where to start from?
    Any help will be appreciated.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Finlux 32h7072-no backlight
    Images of the boards used in the set please ?
    • Bizzy80
      • Aug 2016
      • 5
      • United Kingdom
      I will post some pics when i'll get back home as i'm away right now.
      As an update when i was trying all the options on the menu( with a flashlight to see it properly) ...on power save mode when i was choosing eco mode the screen sometimes was getting on...like for a 1/2 second
      • Bizzy80
        • Aug 2016
        • 5
        • United Kingdom
        I have atached the pictures:full back and each board...sorry about landscape/portrait mode...i was trying to get a closer and clear picture.
        I've looked at the psu board and there is nothing showing damaged...no blowed caps or some other signs
        I did make a test on the led output...when i power up the tv is somewhere around 90v then drops and fluctuates between 27.1-27.3v
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Watch this please:
          https://www.badcaps.net/forum/showth...t=Led+stacking
          • CapLeaker
            Leaking Member
            • 8119
            bad LED backlight
            • Bizzy80
              • Aug 2016
              • 5
              • United Kingdom
              Thanks guys! As i assumed the result was a faulty led...I've just ordered a new led strip...Waiting now to get it delivered.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ok keep us updated
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • stoian_93
                  Finlux LED backlight not working
                  by stoian_93
                  Hello guys!
                  My Finlux TV backlight stopped working. I disassembled the TV, saw I don't have the tools to replace the backlight and assembled it again without replacing anything. So then the backlight started working again.
                  A day after it is also not working.
                  I decided now to remove the back cover and get the output voltage to the backlight. I placed the TV facedown and connected to the mains, so - nothing. I disconected, removed the cover and connected again to the mains and then the backlight lighted again. So strange.
                  Output voltage when light is 66V.
                  Board: VESTEL...
                  08-19-2023, 12:32 AM
                • vf fa
                  EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                  by vf fa
                  Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                  I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                  So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                  01-31-2024, 01:40 PM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • JaquesPratt
                  Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                  by JaquesPratt
                  I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                  This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                  07-16-2024, 01:04 AM
