Re: 17IPS20 No Led Voltage Solved With Video
Well as promised spent an extensive day of checking and testing using your suggestions.
First with all components in and no power on I checked the following readings:
on 200 ohm scale:
Pin 13 to ground = 11.4 ohms
R522 to ground = 11.4 ohms
C519 + to ground = 11.4 ohms
C 519 - to ground = 0.2 ohms
R522 out to ground = 0.4 ohms.
R522 disconnected from Pin 13 trace then Pin 13 to ground reads 1
C519 removed and tested on 2M scale reads 6.6 continually rising.
With R522 and C519 removed Pin 13 to ground reads 1 on all meter resistance scales
With R522 and C519 removed Pin 13 to Pin 4 reads 1 on all meter resistance scales C519 reinstalled then Pin 13 to ground reads 1 on 200- 2M scales
R522 reinstalled as well then Pin 13 to ground reads 11.4 ohms (Obviously the resistors value of 11 ohms)
From all of the above and rechecking all solder joints I felt I could move to live testing (hopefully).
With LEDs left disconnected I powered up the boards. No obvious shorts or bangs and no magic smoke but also still no 156-160 voltage either.
Following readings then taken:
On Standby Vin = 16.4 volts
On Standby Vcc = 0 volts
Power on Vin = 10.8 volts
Power on Vcc = 5.0 volts
Voltages measured at main board connector:
12 volt shows 16.4 volts
24 volt shows 33 volts
3.2 volts shows 2.2 volts now
So still something not functioning correctly - any suggestions as I am now out of ideas and readings?
on 200 ohm scale:
