Help with Toshiba 50L2300U
  • 2many
    • Jul 2016
    • 28
    Hi, Need help on a 50" Toshiba L2300U series LED TV. Less than 3 years old and the LED back light just went out. Has sound and picture (with a flashlight). I got the front bezel and back panel off (what a pain!). I poked around the power supply board near the LED power connector with an ohmmeter and found 2 shorted Schottky barrier diodes and a shorted N channel Mosfet (I have some experience in electronic circuitry but not with LED TV's). I could not get the exact p/n replacements but replaced them with components that are higher spec in volts and current.
    Unfortunately, I did not take any voltage measurements before I replaced the 3 bad components. After plugging in the power supply board, the unit would not power up with the remote or the power button on the main board. I took power supply voltage readings at the connector and they are as shown below. I am not sure what to do next to get the TV to power on to see if replacing those 3 parts helped. When the front bezel was pryed off, the IR sensor and LED indicator connector just ripped off. It does not look damaged. I have not tested continuity of the wires at the IR sensor or LED indicator but will do so. Any help appreciated.
    This is the power supply board. The 2 bad Schottky barrier diodes were SR3150 and replaced with 2 dual diodes MUR3020PT (use 1/2 of each). The N Mosfet was PO920ATF and replaced with IRF640
    Re: Help with Toshiba 50L2300U
    Can we see the straight shot pictures of the whole power supply/LED driver board?
    I also need the P/N as printed on the BARCODE stickers.
    • chrismurphy
      • May 2014
      • 251
      • australia
      Schottky barrier diodes cannot be replaced with the ultrafast diodes you put in
      you need to replace the diodes with the correct ones .The FET should be ok
      • 2many
        • Jul 2016
        • 28
        Here's pic of entire board after removal of the 2 didoes and FET (middle one bottom of pic). I'll get numbers on the stckers later.
        • 2many
          • Jul 2016
          • 28
          Stickers
          B178-B01 C52 REV.C 20 00014 19296 02366
          03-PK101W01001-VDAFL-C50-5100-100
          • 2many
            • Jul 2016
            • 28
            Thanks for that info. I have these http://www.ebay.com/itm/361553588394...%3AMEBIDX%3AIT coming in the mail. They are higher voltage and current. Will these be ok?
            Do you think having the ultra fast diodes in there have anything to do with not being able to power on the TV?
            • 2many
              • Jul 2016
              • 28
              Here's a clearer pic of the board as it stands
              • whiz62
                whiz62
                • Dec 2013
                • 242
                • usa
                Hello 2many. Hope you get it going. If you need any boards I have a new TV with cracked screen that I got from a dealer. It will fire up. Been sitting in garage for couple of years. Got too many and need to start cleaning out.
                • 2many
                  • Jul 2016
                  • 28
                  You have the exact same set? I'll keep you in mind if I can't fix it.
                  • 2many
                    • Jul 2016
                    • 28
                    Where can I get a schematic/ service manual for my Toshiba 50L2300U? I searched these 2 resources from LongJohns but could not find my TV
                    http://www.electronica-pt.com/index....,select/id,13/
                    or
                    http://www.eserviceinfo.com/
                    • whiz62
                      whiz62
                      • Dec 2013
                      • 242
                      • usa
                      Yes 2many. It is the same model #. Just let me know if you need anything.
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Try toms-service-manuals.com for service manuals.
                        • 2many
                          • Jul 2016
                          • 28
                          The SR5200 Schottky diodes arrived this afternoon from China. I replaced the 2 ultra fast diodes with them but it didn't help, still won't power up.
                          Can't believe it was powering up and had sound before I did work on the power supply board, afterward that it wouldn't power up no more!
                          What do the voltage readings above indicate?
                          I can really use some help or a service manual / schematic.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Start from the beginning. With the mainboard disconnected what voltages do you have on the power supply as listed in Post #1
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Toms service manuals.com and elektrotanya don't have the service manual but i did found this. Its the 32" model but that will be the same i think.
                              http://electronicshelponline.blogspo...0-led-lcd.html
                              Hope this helps you a bit buddy
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                The picture of the PS is different but basics will be the same. Strange the power supply does not work anymore after working on it. you did not bend the board? Maybe bad solder joints somewhere?
                                • 2many
                                  • Jul 2016
                                  • 28
                                  OK. With main board disconnected, pins 10 & 14 = 5.1 V, all other pins = 0 V
                                  • 2many
                                    • Jul 2016
                                    • 28
                                    That is not correct. The TV was powering up with the remote and had sound but no backlight (no picture unless I shine a flashlight on the screen). After I replaced 2 diodes and a FET on the LED power section, it stopped powering up.
                                    I buzzed out the IR board and LED indcator connector harness to the main board and there was good continuity on all wires. I thought I may have broke some of those wires during front bezel removal but they are fine.
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      Ok just looking at your last comment makes me think the power supply was good but you have bad leds. As they most of the times are in series , if 1 dies the rest won't work anymore....
                                      Now i understand why you want to turn on the leds in the other thread to see if they are ok. Well i would just remove the panel tbh.
                                      Its not that hard and if you tape the small tabbond prints to the panel nothing can go wrong if you are gentle.
                                      The plastic underneath the lcd is easy to remove and you will get easy acces to the leds.
                                      • 2many
                                        • Jul 2016
                                        • 28
                                        Moreno83, please read the first post in this thread. It gives a history of what transpired.
                                          09-06-2024, 05:27 AM
                                        • Dvsr
                                          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                          by Dvsr
                                          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                          After replacing the caps I started testing out the speaker. It seemed...
                                          09-10-2025, 10:20 AM
                                          09-06-2024, 05:59 AM
