Panasonic TC-P60U50 7 blinks, then 8
  • throwback
    • Jul 2016
    • 4
    I have no real experience with TV repair, but some with general hardware service and repair.
    I have a 60" Panasonic plasma tv (model TC-P60U50) and the power led started blinking 7 times. After looking up the blink code I tried disconnecting the ribbon and power connectors from the Y sustain board. When reconnecting the power I got 8 blinks instead. From what I've seen on other forums (discussing other model number Panasonic plasmas) this means that both my Y sustain and buffer boards are hosed. I don't mind ordering new ones and swapping them out, but I was wondering if this is actually correct.
    Am I on the right track here, or just moving around deck chairs on a sinking ship?
    thanks.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P60U50 7 blinks, then 8
    thanks.
    doing that just means the A-board is reporting correctly. 8 blink is what you get with sc20 removed.
    With 7 blinks I would disconnect the 3 connectors from the SC to the SD/SU. remove the 4 earthing bolts on the sd/su that bolt to the SC.
    On the SC , locate the small 2 pin connector sc50, jumper/short those 2 pins together.
    turn the TV on and if it no longer has 7 blinks and turns on with no errors then it will be either or both buffer boards.
    If it still 7 blinks then it's SC and you will have to check the sd/su boards too.
    these buffers are cheap at Shopjimmy. If they are faulty, I'd consider getting a an extra set for a rainy day as they are nearly out of stock. SC board also cheap and worth getting as spare.
    As with all other models at some point you can't get spares so grab them while you can if you want to keep the TV for a long time.
    You can determine which buffers are bad with a multimeter check for shorts between the Vfg ground point on the buffer and all the output pins.
    • throwback
      • Jul 2016
      • 4
      Thanks for that. Lower buffer board has several shorts. It's good to know which part to order a spare for.
      cheers,
      throwback
      • tw2005
        • Oct 2011
        • 6458
        cheers,
        throwback
        Good luck. I still think grabbing full spare set of boards while you can could be handy in future
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Hell yes!!! No shame in hoarding stuff you will actually use!
          You can always make a buck on them to fix the next one.
          • throwback
            • Jul 2016
            • 4
            Already ordered. Two of the dead board, one of the live, and a fresh Y sustain just for giggles. I figure that once I have them I'll never need them. That's usually how the world works for me.
            • tw2005
              • Oct 2011
              • 6458
              Maybe but if you do you can pat yourself on the back and once they become rare of hard to get you will get more than what you paid. My 2011 models the buffers are very hard to find and expensive so mu c h that for me I've replace the chips to salvage the board and save money.
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                11-20-2024, 08:52 PM
              • howardc64
                by howardc64
                Yesterday, 05:17 PM
              • Biruslapio
                Panasonic P58V11B 8 and 12 blinks error "fix"
                by Biruslapio
                Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                04-13-2021, 07:13 AM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • Alicat
                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                by Alicat
                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                Model number is TH-50PZ85U
                Power comes on and the red power light stays on solid.
                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                I also hear a few clicks.
                I also think my parents said there was a thunderstorm and the TV failed after that.
                Section 6 in the service manual talks about power and no screen,...
                10-30-2024, 10:09 AM
