Samsung PS51d6900 not so well
  • dave247
    • Jul 2016
    • 6
    • England
    I have always liked this set and the picture has been great. However, a couple of weeks back (during the football ) we had a small power cut, a few seconds at best. The TV turned off and on and was fine. For the next few days it turned itself off and on a couple of times until eventually it turned off and stayed that way with just sound coming back briefly for around a minute. When unplugged at the mains and re connected it turned on but no standby light, the led just flashed 5 or six times so something was on but no picture.
    The result is I now have a 55 inch lg (not oled) which is nice but I do not think the tv is as good for films so I want to fix my plasma.
    I removed the back panel and noticed that the green led on the logic board was not flashing at all, not even lighting. I tested a few voltages as per threads here but was not getting the readings expected. I bought a replacement logic board, I now have standby, the set turns on and off with the remote and the green light flashes every second. However still no form of screen activity.
    I have the set in a separate room now with no input source which does not help but I expected to be able to see something on the screen, even the Samsung test screens do not show when I short the logic board clips as per their video.
    I have taken readings and some appear very wrong.
    They are as follows,
    In standby I have a 5.2v reading on the standby plug
    PS on also has 3.28v so all good there.
    When I check PS on at switch on it goes from 3.28 to 168v, according to the Sammy video this is wrong and should be 0?
    VS on at turn on give 3.29v so that is fine.
    VA should be 58 and reads 58
    VSC should be -187 and reads -186.2
    VS shold be 207 and reads 207
    BUT VE should be 80 and reads 191.3. How did this happen?
    So as far as I can see I have two incorrect readings and thought it was best to get help at this time before going any further.
    This is a view of the set as it stands. I cannot see any problem capacitors or problem areas.
    "y" side
    "X" and main.
    Power supply
  • sordids999
    • May 2013
    • 2152
    • uk
    Re: Samsung PS51d6900 not so well
    Check here first https://www.badcaps.net/forum/search...archid=6827103
    • dave247
      • Jul 2016
      • 6
      • England
      Originally posted by sordids999
      Thank you for responding, I had done that search and also read the plasma repair tips thread but seem to be going in circles now.
      I hoped to get an idea of what approach to take with the tests and results I had posted because they are not meaning too much to me just now. In time they may but I do not want to damage the set switching it on and off without a real steer.
      • sordids999
        • May 2013
        • 2152
        • uk
        have you tried running test patterns ?
        have you tested the buffer board ?
        • dave247
          • Jul 2016
          • 6
          • England
          Yes,
          Tried the test pattern if that is connecting the two upper pins on the logic board, nothing showed. I have run the meter over the y buffer connections whilst in place but probably not ideal, I could disconnect the ribbons again and remove the board completely. It was those voltage readings that made me hold up a little.
          I probably should test the buffer. I will do it and post the result later. There is a copper ground spot on the board, I take it that is where the meter probe sits while I run it over the pins?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Originally posted by dave247
            Yes,
            Had you removed the LVDS cable to the Logic board when you carried out the test?
            • dave247
              • Jul 2016
              • 6
              • England
              Yes, I followed the Samsung video on youtube, just tried it again after testing y buffer, nothing. Powers on, green light flashes.
              Buffers seem ok, I used one of the pins on the block which triggered a noise on the meter when the other pin was on ground
              Still getting192v on VE but the sticker says 80? Maybe should just get an X sus board
                09-07-2024, 05:50 AM
              • ChristianBr01
                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                by ChristianBr01
                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                04-23-2025, 01:48 AM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
                09-06-2024, 11:40 PM
