Problems with Samsung UE55ES7000
  • angel-boy
    • 550
    • Romania
    - the tv power up great first time, if i want to change channel to a HD channel, image is freezing and restart ( not allways ) . Appers Smart TV LOGO , no image, and still restarting, i have to unplug from power line and wait few minutes.
    - If i let the tv to History HD for exemple, i try to increase the volume , freeze and restart.
    - the wireless module is broken , and i try software update by usb.
    - I think mainbe is a problem with graphic chip or memory ? possible to need a reballing ?
  • Diah
    • Feb 2013
    • 6344
    Re: Problems with Samsung UE55ES7000
    did you disconnect the wifi socket since its had error,?
    also try Disable BT and check HD programm
    • angel-boy
      • 550
      • Romania
      I remove WI-FI module , o will try to disable bluetooth from service menu. and try again.
      and if still not working ?
      i forget to tell you ,sometimes the tv power up , only logo , no command from remote, and restarts....
      • Diah
        • Feb 2013
        • 6344
        dont do it from service menu to disable BT. just plug it out as you did with wifi, after that u should make hard reset from service menu.. and check urs HD
        i just read your edit, yes this fault known by UE ES7xxx and UE ES8xx and it was the reason of wifi . BT , smart hub and firmware update
        • angel-boy
          • 550
          • Romania
          i remove today bluetooth module, i try to search for channels , and the tv frezee and restart, after that , works !
          Tomorrow i will test only with HD channels , and turn on/off.
          I need to update or install firmware ? a working version or latest version ?
          • Diah
            • Feb 2013
            • 6344
            latest version of course.. and if you find early 0.0.0.0 version of firmware will be better that you can reset errors record of wifi
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Common issue is the Psu to Mb power cable failing and corroding check the Sm for this tv.
              • angel-boy
                • 550
                • Romania
                Schematic ?
                @Diah , can you help me with a working firmware ?
                • angel-boy
                  • 550
                  • Romania
                  I check and seems to be old problem with 5v rail , but , now the ci+ chip fail .
                  how can i change the chip of ci+ ?
                  • thoma
                    • Sep 2012
                    • 268
                    http://documents.tips/documents/2012...set-issue.html
                    regards thoma!
                    • Diah
                      • Feb 2013
                      • 6344
                      there is new firmware Ver. 2021.0 date 24. May.2016
                      http://www.samsung.com/at/support/model/UE55ES7000SXXH
                      • angel-boy
                        • 550
                        • Romania
                        i solve the problem of bad connection between power board and mainboard, now i have to solve the problem with CI+ error
                        • Diah
                          • Feb 2013
                          • 6344
                          the old firmware of 0000 to hack it and reset error
                          https://www.dropbox.com/s/lxwaqr8h9c..._0000.zip?dl=0
                          • angel-boy
                            • 550
                            • Romania
                            Ok , and to reset error ? how can i do this ? from service menu ?
                            The last firmware, when i want to update , tells me that no files on usb .
                            • Diah
                              • Feb 2013
                              • 6344
                              for error reset and hack the service menu you should downgrade it to the 0000,
                              CI+ had nothing to do with firmware.. there are allot working arround on the web how to trick it to ride of error.
                              • angel-boy
                                • 550
                                • Romania
                                i manage to downgrade the tv firmware, but still not working the CI+
                                • Diah
                                  • Feb 2013
                                  • 6344
                                  which type of cam you are using?
                                  • angel-boy
                                    • 550
                                    • Romania
                                    I tested with 2 ci adapters, still not working,
                                    i get this error if i press mute+247+exit
                                    • angel-boy
                                      • 550
                                      • Romania
                                      any help with this problem ? where is the chip that is for CI+ ? can you find schematic for this board ?
                                      • Diah
                                        • Feb 2013
                                        • 6344
                                        i think you are doing wrong,
                                        with this series ES you cant just CI+ module alone to install with out any program signal supported by module. this mean.
                                        first turn the TV ( program ) channel on sender used CI+, after that turn the TV to standby and then put the module at CI socket with out Smart Card. turn on the Tv it will identification and install the module, after it registered put the Smart Card in the module.
                                        between after you downgrade the firmware and finished the error reset or any modification like region or turn on any other hidden service. you need to updrade the firmware to the last one as its support more CI modules .
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
