Samsung 46EH5300 - Red LED blinks at single intervals, won't turn on
  • MadeJust
    • Apr 2016
    • 32
    Re: Samsung 46EH5300 - Red LED blinks at single intervals, won't turn on
    Ok, let me try this again. I'm sticking the piece of wire into the cable side of the connector with it still plugged in. Better readings.. (Sorry this is new to me)
    Pin 2 - 0.9v
    Pin 4 - 12.8v
    Pin 6 - can't get proper reading
    Pin 8 - 0v
    Pin 12 - 5.3v
    Pin 14 - 3.3v
    • MadeJust
      • Apr 2016
      • 32
      I *think* this tells me the PSU is ok.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It looks as though the power supply is working but knowing Pin 6 (Backlights ON) voltage at switch on out of standby would be helpful. Can you measure it on the bottom of the board.
        If anyone else can offer some advice here I'm sure the OP would be grateful for your assistance.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Can you disconnect the main board from the power supply and connect the 5V (pin 12) using a 1K resistor to BLU_ON (Pin6) and see if the backlights come on.
          • MadeJust
            • Apr 2016
            • 32
            Ok I'll try that. Any tips on how to go about it so I don't accidentally hit another pin? My hands aren't as steady as they used to be.
            Meanwhile, if I have to order a replacement main board, which numbers have to match? I've found a couple with the same model number, but have slightly different numbers on the bottom of the label:
            BN94-06711J, whereas mine is BN94-06880A. The other label number matches though with BN97-06298N
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              You can connect the resistors between the pins by soldering them to the underside of the board and make sure the legs are not touching anything else eg the chassis.
              • MadeJust
                • Apr 2016
                • 32
                Hi, sorry for not following up sooner. I just installed a replacement board and it's the same thing, blinking red light, no power.
                  09-07-2024, 05:50 AM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
